Following up on this. Epic ball of FAIL on the motion sensor switch.
Hoping maybe my esteemed colleagues might have some ideas on troubleshooting before I send this puppy back to Amazon. If you take a look at the image here:
http://www.amazon.com/gp/customer-media/permalink/mo3UCZJASQVR0UP/B0010W3PBI/ref=cm_ciu_images_pl_link
the switch I got is the one on the right.
The switch has four wires coming out:
[ol]Black (hot)
White (neutral)
Red (load)
Green (ground)[/ol]
There are 3 wires in the box where I’m installing the switch, black, white, and bare copper.
I’m fairly certain that I’ve wired the switch correctly per the diagram, with black to black, green to ground, and white to neutral and load. I also used an outlet tester to make sure that the wires in the box were actually what their color indicated as well, and they tested fine.
But when I put the switch on “Auto” (the setting where the light should be turned on and off by the sensor), it simply clicks on and off repeatedly until I either switch it to the on or off position.
This switch is supposed to be able to handle both fluorescent and incandescent lights, and I’m using it on a circuit that has two 3’ dual-tube fluorescent shop lights, nothing fancy.
Has anyone messed with these switches before and seen something similar? I noticed that there were a couple of other folks who’d reviewed the switch who seem to have run into this, but I’m wondering if that means that every so often there’s a bad switch, or there’s something in common that we did wrong, or some other commonality that might help me troubleshoot.
Thanks in advance for any suggestions!
