I have a Lemur and SDK 4.3 with VS 2015. I’m trying to read a DS18B20 on a TinyRTC board. I’ve looked at the examples in Codeshare, but can’t get them to work. So far I have the following errors, it doesn’t recognise Reset() or SearchRom(). Can someone help please.
PROGRAM.CS
using GHI.IO;
using GHI.Pins;
namespace onewire2
using (var op = new OutputPort((Cpu.Pin)FEZLemur.Gpio.D8, false))
var ow = new OneWire(op);
var devs = onewire2.OneWireBus.Scan(ow, onewire2.OneWireBus.Family.Unknown);
foreach (var d in devs)
Debug.Print(d.Family.ToString());
using (var s = new onewire2.DS18B20(ow, devs[0]))
// do the conversion and read the temperature all at once
Debug.Print(s.ConvertAndReadTemperature().ToString());
Thread.Sleep(1000);
// start the conversion (returns quickly)
s.StartConversion();
// wait for the conversion to happen
Thread.Sleep(1000);
// now, read the temp
Debug.Print(s.ReadTemperature().ToString());
DS18B20.CS
using System.IO;
using System.Text;
namespace onewire2
public class DS18B20 : IDisposable
private OutputPort m_op;
private OneWire m_ow;
private OneWireBus.Device m_dev;
public DS18B20(Cpu.Pin pin) : this(pin, null) { }
public DS18B20(Cpu.Pin pin, OneWireBus.Device dev)
m_op = new OutputPort(pin, false);
m_ow = new OneWire(m_op);
if (dev == null)
var devs = OneWireBus.Scan(m_ow, OneWireBus.Family.DS18B20);
if (devs == null || devs.Length < 1)
throw new InvalidOperationException("No DS18B20 devices found on OneWire bus");
dev = devs[0];
m_dev = dev;
public DS18B20(OneWire ow) : this(ow, null) { }
public DS18B20(OneWire ow, OneWireBus.Device dev)
m_ow = ow;
if (dev == null)
var devs = OneWireBus.Scan(ow, OneWireBus.Family.DS18B20);
dev = devs[0];
m_dev = dev;
public void Dispose()
if (m_op != null)
m_op.Dispose();
public float ConvertAndReadTemperature()
var data = 0L;
// if reset finds no devices, just return 0
if (m_ow.Reset() == 0)
return 0;
// address the device
m_ow.WriteByte(Command.MatchROM);
WriteBytes(m_dev.Address);
// tell the device to start temp conversion
m_ow.WriteByte(Command.StartTemperatureConversion);
// wait for as long as it takes to do the temp conversion,
// data sheet says ~750ms
while (m_ow.ReadByte() == 0)
System.Threading.Thread.Sleep(1);
// reset the bus
m_ow.Reset();
// read the data from the sensor
m_ow.WriteByte(Command.ReadScratchPad);
// read the two bytes of data
data = m_ow.ReadByte(); // LSB
data |= (ushort)(m_ow.ReadByte() << 8); // MSB
// reset the bus, we don't want more data than that
m_ow.Reset();
// returns C
// F would be: (float)((1.80 * (data / 16.00)) + 32.00);
return (float)data / 16f;
public void StartConversion()
return;
public float ReadTemperature()
var data = 0L;
// reset the bus
m_ow.Reset();
m_ow.Reset();
// returns C
public static float ToFahrenheit(float tempC)
return (9f / 5f) * tempC + 32f;
private void WriteBytes(byte[] data)
for (var i = 0; i < data.Length; i++)
m_ow.WriteByte(data[i]);
private static class Command
public const byte SearchROM = 0xF0;
public const byte ReadROM = 0x33;
public const byte MatchROM = 0x55;
public const byte SkipROM = 0xCC;
public const byte AlarmSearch = 0xEC;
public const byte StartTemperatureConversion = 0x44;
public const byte ReadScratchPad = 0xBE;
public const byte WriteScratchPad = 0x4E;
public const byte CopySratchPad = 0x48;
public const byte RecallEEPROM = 0xB8;
public const byte ReadPowerSupply = 0xB4;
OneWireBus.CS
using System.Collections;
namespace onewire2
public static class OneWireBus
public class Device
public byte[] Address { get; private set; }
public Family Family { get; private set; }
internal Device(byte[] addr)
Address = addr;
switch (addr[0])
case 0x10:
Family = OneWireBus.Family.DS18S20;
break;
case 0x28:
Family = OneWireBus.Family.DS18B20;
break;
default:
Family = OneWireBus.Family.Unknown;
break;
public enum Family : byte
Unknown = 0x00,
DS18S20 = 0x10,
DS18B20 = 0x28,
public static Device[] Scan(OneWire ow, params Family[] includeFamilies)
var list = new ArrayList();
var all = false;
var devs = ow.SearchRom();
if (includeFamilies != null)
foreach (var f in includeFamilies)
if (f == Family.Unknown)
all = true;
foreach (byte[] da in devs)
if (includeFamilies == null || includeFamilies.Length == 0 || all)
list.Add(new Device(da));
if (da[0] == (byte)f)
return (Device[])list.ToArray(typeof(Device));
public static Device[] Scan(Cpu.Pin pin, params Family[] includeFamilies)
using (var op = new OutputPort(pin, false))
return Scan(new OneWire(op), includeFamilies);
