I recently purchased Panda II board and experiencing problems with on-board LED and extended ports D20 - D51.
When I connected to Panda II board for the first time on-board LED was blinking. After putting 4.1.8 firmware on it , it stopped blinking.
I created the basic program that comes with default Panda II template that make on-board LED blink. When running it under debugger it steppes correctly but LED doesn’t blink. I connected Adafruit Protoboard and run the same code addressing LED to different pins - it worked perfectly.
Same thing with extended Panda II pins (D21 - D52) - they do not respond when basic pins do!
Is there anything else to do to fix it short of replacing the board?
namespace FEZ_Panda_II_Application1
// Blink board LED
bool ledState = false;
OutputPort led = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, ledState);
// Sleep for 500 milliseconds
Thread.Sleep(500);
// toggle LED state
ledState = !ledState;
led.Write(ledState);
First step to try is to make sure you are referencing latest assemblies.
-Open the References folder in your solution explorer.
-Remove all references to GHI assemblies (you should have only one -FEZPanda_II_GHIElectronics.NETMF.FEZ)
-Add them back
After you have added the reference back. check its Version in the Properties window. Make sure it matches your firmware.
