I’m updating the OLED code to work using my TinyBitmap class (basically a straight 2bpp array) instead of Bitmap for use w/ Cerb40 and other devices. On the Hydra the standard driver can write just under 2 frames per second. (1 frame = ~0.53879sec).
My version which flushes the straight array clocks in at ~36 frames per second. (1 frame = ~0.029172sec).
I’ll make then entire thing available once it is complete.
Nope, that’s all managed code.
I will look at RLP eventually but at the moment, it’s not needed for this project if it can churn out frames like that.
Very good performance increase.
Skewworks, you’re awesome.
Just wait til I add methods for the built-in vertical and horizontal scrolling.
Basically redoing Spiral for it.
Simply using the array boosts the speed up so I’ll put in open source methods for that, scrolling and color inversion.
