OK.. Codeshare Modify. I cannot modify (edit) the text
Well, I can edit the text but I cannot find a way to save the changes. All I see is the modify button at the bottom and I’m back where I started.
I know, this should be simple BUT not for me…
All I wanted to do is correct the broken text lines. The text looked OK when I first entered it, but it had broken lines when I viewed the post.
Maybe the new line breaks are getting removed due to html markup. Try to modify a word and see if that works.
When I try to modify, I see a button that say “modify entry” and then it saves the changes.
Changing the codeshare text will not change the forum. It is only copied the first time you submit.
