You disable the glitch filter in your define. This is with it enabled:
InterruptPort LDR = new InterruptPort((Cpu.Pin)0, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
the rest of the code stays as it is…
Thanks, but glitch enabled has the same effect: no blinking
just surprising: the same program with Panda II runs as exspected :
This is weird! Does the Rhino button works normally? (Gets interrupts when you press it). Try another I/O on the Rhino as a button asd see if it works
Yes it does: the interrupt with [italic]LDR-Button pressed[/italic] is coming bevor “hivernating”. I can also not understand, why Rhino sucks [italic]more [/italic]current in “hibertnation”
