Starting in the next SDK, we will have updated the USB drivers to default to WinUSB. The current NETMF Interface drivers will be included in the installer as legacy drivers, but they will not be used by default. If you have trouble with WinUSB, you can fall back to the legacy drivers.
Since USB drivers are so important to the SDK, we’d like to release them as a beta first to make sure everything is stable and solid. Please download and install the following based on whether your operating system is 32bit or 64bit and let us know about any problems or issues you encounter with them.
Please also make sure to uninstall the old drivers first. The old and new installer have different product codes, so an upgrade is not possible. The boot loader serial driver has not changed in this upgrade.
The WinUSB drivers themselves were built last year, similar to how the old NETMF Interface drivers were built back in 2010. The installer was built and signing occurred just a few days ago, though.
@ John - Sorry, but I’m a little confused! Have the WinUSB drivers been updated? If we already use the WinUSB drivers from the previous release do we need to update? Thanks.
@ jasdev - Architect is correct. These WinUSB drivers are exactly the same as the ones you can manually install in the current SDK. This installer just has proper code signing and will install WinUSB by default instead of you having to manually do it. If you are already using WinUSB, you don’t need to use this, but the more we have testing it, the better. Just incase a bug was introduced, we would want to find it before release.
VS and FEZConfig simply do not recognize them, although they all are present in Device Manager. It’s kind of weird, and I can’t find a reliable failure pattern. Sometimes some of the devices simply do not work. Although I suspect USB3 ports a little bit, but not sure… Or maybe it’s due to some kind of magnetic storm. These things happen
Is it just happening when you have all three connected? G120, G400, EMX. Or can you get it to happen with any number and combination of devices? Are they plugged into USB3 ports?
