Booting up new Raptor for first time … little luck.
Have power plugged in to port 8. Power light comes on, on mainboard.
Tried multiple USB ports, 2.0 hubs, and other PC’s … none of which seemed to act as-if any USB device was being connected. (FWIW, same PC’s talk to a Spider with no issues.)
External power - no change.
Decided to see if I could update TinyBooter. Did the short the pins trick, and hit reset. that got me something … a USB device.
After a bit of futzing w/ run as administrator, etc … programG400 COM9 … updating will start and then fail. Log file says “Error during external ram initialization”. (Full log, below.)
Running out of troubleshooting ideas.
Anything else to try, before concluding there’s an issue w/ the board?
-I- Waiting …
-I- TCL platform : Windows NT
-I- SAM-BA 2.12 on : windows
current connection is \USBserial\COM9, \USBserial\COM9 to be matched
-I- Retrieved arguments from command line :
-I- argv 0 : \USBserial\COM9
-I- argv 1 : at91sam9g15-ek
-I- argv 2 : G400TinyBooter.tcl
-I- Connection : \USBserial\COM9 (target(comType) = 0)
-I- Board : at91sam9g15-ek
-I- Traces Level : 4
-I- target(handle) : 65105344
Read device Chip ID at 0xfffff240 — get 0x819a05a1
-I- Found processor : at91sam9g15 (Chip ID : 0x819a05a1)
sourcing device file C:/Program Files (x86)/GHI Electronics/GHI Premium NETMF v4.2 SDK/G400/Firmware/TinyBooter/sam-ba.exe/…/tcl_lib/devices/at91sam9g15.tcl
sourcing board description file C:/Program Files (x86)/GHI Electronics/GHI Premium NETMF v4.2 SDK/G400/Firmware/TinyBooter/sam-ba.exe/…/tcl_lib/at91sam9g15-ek/at91sam9g15-ek.tcl
-I- Loading applet applet-lowlevelinit-sam9g15.bin at address 0x300000
-I- Memory Size : 0x0 bytes
-I- Buffer address : 0x4
-I- Buffer size: 0x0 bytes
-I- Applet initialization done
-I- Low level initialized
-I- External RAM Settings : extRamVdd=0, extRamType=1, extRamDataBusWidth=32, extDDRamModel=0
-I- Loading applet applet-extram-sam9g15.bin at address 0x300000
-E- Error during external RAM initialization.
-E- External RAM access is required to run applets.
-E- Connection abort
