Hi All, been a while in the works and finally finished my pricing based on some measurements I needed to finish up this week.
I don’t have all of the info up in the store on the site yet, but here’s what I’m offering as “Stock” pieces currently:
I have designed a Uni-Mount layout that will let you mount your favorite board to a thickness of acrylic of your choice (3.5, 4.75 or 6.5mm) in the color of your choice from two different suppliers (Complete color list below). The mount has a single row of Gadgeteer spec mounting holes all the way around the edge and works with the following boards (from smallest to largest):
Mountaineer USB
Mountaineer Ethernet
FEZ Cerberus
FEZ Spider
NetDuino GO
FEZ Cerbuino Bee / FEZ Panda / NetDuino / NetDuino Plus / Arduino Mega R3 / Uno / Leonardo
FEZ Hydra
This mount measures 71mm by 95.5 mm, again available in 3 thicknesses - 3.5, 4.75 and 6.5mm (pic 1)
I also have this mount available as a solid grid option called the Uni-Grid (pic 2)
Prices start at $2.50 USD.
Edit: Costs and color/size availability are now updated online - http://devonboard.com/mounting-boards
Now, here come the options.
I also have 5 (that’s right 5!) sizes of additional boards to choose from.
Size SMALL incorporates either a medium sized breadboard or grid to the right of the UniMount/UniGrid (pic3) 136mm x 95.5mm
Size MEDIUM incorporates a 27 x 19 grid below the SMALL board (pic4) 136mm x 191mm
Size LARGE incorporates a 14 x 38 grid to the left of the MEDIUM board (pic5) 201.5mm x 191mm
Size XLARGE incorporates another 14 x 38 grid to the RIGHT of the LARGE board (pic6) 267mm x 191mm
Size XX LARGE incorporates a monster 54 x 19 grid above the XLARGE board (pic7) 267mm x 276.5mm
Costs are as follows:
SM - Starting at $4 USD
MED - Starting at $7 USD
LG - Starting at $11 USD
XL - Starting at $15 USD
XXL - Starting at $22 USD
All of these are being cut and engraved on my CNC mill - I’m still in the process of building my laser cutter frame, but I would expect similar prices as either machine still has to cut the acrylic/HDPE/UMHW.
The machining time on the larger and thicker material really starts to add up - for instance, it takes just over an hour to cut the mounting holes out on an XXL board, then another 5 minutes to do the engraving.
I can add additional engraving text in the middle of the board mount area or above/below the breadboard mount area (see pic 8 to get an idea from an older design), or add an additional “dead” area with your text as shown in pic 9.
Price for engraving depends on the size of the extra space, but likely only $1-2 dollars per board extra. Engraving in an existing space is free, assuming it fits.
Colors available are:
Clear
Translucent - amber, blue (8 shades), cherry blossom (light pink), green, ivory, orange, pink, purple, red, white (31% light blocked), yellow
Fluorescent - blue, green, red, yellow
Transparent - bronze, gray
Opaque - black, blue, green, red, white, yellow
I also have some metallic/glitter embedded finish Translucent colors available. Add $1 per SM/MED/LG board and $2 per XL/XXL board for these colors:
Translucent Black with Silver Glitter
Translucent Blue with Royal Blue Glitter
Translucent Light Green with Sea Green Glitter
Translucent Medium Green with Dark Green Glitter
8 other Translucent colors w/ different sparkle colors (samples coming soon)
I also have some mirrored / metallic surface finish sheets on order, will need to test those with the engraving and see how they do. They may be slightly more expensive.
If you’d like to have your own custom layout made, just drop me a note. Also, I’ll shortly have an option for you to draw up your board and just send me the file to cut, just need to verify one thing tomorrow before I post instructions.
Additionally, I will have the fastener/standoff options priced out in the store tomorrow as well.
The pricing above is introductory pricing, good through 12/31. Prices are subject to change after that. I do also offer quantity discounts of the same or mixed combinations of the boards as well as the fasteners.
Please let me know if you have any questions - just shoot me an email to info at DevOnBoard dot com!
Steve
