I tried to update my Hydra’s firmware but when I was asked to press the reset button and wait for the onboard LED to blink three times, it blinked only once so I could not go any further (the “next” button remained grayed).
Now, when I plug the board via USB, the onboard LED don’t turn on (only the power LED does) and the board does not respond.
Did I brick my Hydra?
If yes, is there any way to unbrick it?
I tried the trick with pin 8 and 10 of socket 3 but it did not help.
I read a lot of information and now I’m a bit confused.
btw it would be great if you guys could include all the current Display profiles in the FezConfig tool as a drop down list… right now i’d have to fetch the docs to get the correct setting for each display… unless i’m missing something!!!
Hello, where is it possible to download this tool, now? all links that I find seems to be dead… I use the NETMF SDK 4.2 (RTM QFE2) , and this tool is not included, as far I can see…
Removing all traces of the FEZ Config tool is very aggravating to those of us still using a previous SDK for our products. I’m not updating all my products just so I can get the tool. Please provide a separate download.
The FEZConfg tool is currently only included in the SDK.
There is no separate installer anymore.
You have to install the SDK at least once.
Then you can copy the FEZConfig directory to any computer you like, and browse for the firmware files when you want to update a device.
Do you mean with SDK the “Microsoft .NET Micro Framework 4.3 (QFE1)”?
This I have downloaded and installed. Now I have the folder Microsoft .NET Micro Framework with v3.0 to v4.3 but there is only the MFDeploy.exe to find.
