Hi Guys,
Juts put the new firmware on and if I create a new FEZ Cobra Window Application from the templates and then build I get this:
------ Build started: Project: FEZ Cobra Window Application1, Configuration: Debug Any CPU ------
Build started 22/10/2010 07:16:13.
CoreResGen:
"C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\bin\resgen.exe" /useSourcePath /r:"C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\FEZCobra_GHIElectronics.NETMF.FEZ.dll" /r:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Graphics.dll" /r:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll" /r:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll" /r:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.TinyCore.dll" /r:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll" /compile Resources.resx,obj\Debug\FEZ_Cobra_Window_Application1.Resources.resources
Processing resource file "Resources.resx" into "obj\Debug\FEZ_Cobra_Window_Application1.Resources.resources".
CoreCompile:
C:\Windows\Microsoft.NET\Framework\v4.0.30319\Csc.exe /noconfig /nowarn:1701,1702 /nostdlib+ /errorreport:prompt /warn:4 /define:DEBUG;TRACE;MF_FRAMEWORK_VERSION_V4_1 /reference:"C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\FEZCobra_GHIElectronics.NETMF.FEZ.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Graphics.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.TinyCore.dll" /reference:"C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll" /debug+ /debug:full /nowin32manifest /optimize- /out:"obj\Debug\FEZ Cobra Window Application.exe" /resource:obj\Debug\FEZ_Cobra_Window_Application1.Resources.resources /target:exe GPIOButtonInputProvider.cs Program.cs Properties\AssemblyInfo.cs Resources.Designer.cs
EnsureEndianAwareDirectories:
Creating directory "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\le".
Creating directory "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\be".
Creating directory "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\bin\Debug\le".
Creating directory "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\bin\Debug\be".
CopyExeToEndian:
Copying file from "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\FEZ Cobra Window Application.exe" to "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\bin\Debug\le\FEZ Cobra Window Application.exe".
Copying file from "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\FEZ Cobra Window Application.exe" to "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\bin\Debug\be\FEZ Cobra Window Application.exe".
Copying file from "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\FEZ Cobra Window Application.pdb" to "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\bin\Debug\le\FEZ Cobra Window Application.pdb".
Copying file from "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\FEZ Cobra Window Application.pdb" to "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\bin\Debug\be\FEZ Cobra Window Application.pdb".
MetaDataProcessorBE:
C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Tools\MetaDataProcessor.exe -loadHints FEZCobra_GHIElectronics.NETMF.FEZ "C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\FEZCobra_GHIElectronics.NETMF.FEZ.dll" -loadHints Microsoft.SPOT.Graphics "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Graphics.dll" -loadHints Microsoft.SPOT.Hardware "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll" -loadHints Microsoft.SPOT.Native "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll" -loadHints Microsoft.SPOT.TinyCore "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.TinyCore.dll" -loadHints mscorlib "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll" -endian be -parse "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\bin\Debug\be\FEZ Cobra Window Application.exe" -minimize -importResource obj\Debug\FEZ_Cobra_Window_Application1.Resources.tinyresources -compile "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\be\FEZ Cobra Window Application.pe"
MetaDataProcessor:
C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Tools\MetaDataProcessor.exe -loadHints FEZCobra_GHIElectronics.NETMF.FEZ "C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\FEZCobra_GHIElectronics.NETMF.FEZ.dll" -loadHints Microsoft.SPOT.Graphics "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Graphics.dll" -loadHints Microsoft.SPOT.Hardware "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll" -loadHints Microsoft.SPOT.Native "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll" -loadHints Microsoft.SPOT.TinyCore "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.TinyCore.dll" -loadHints mscorlib "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll" -endian le -parse "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\bin\Debug\le\FEZ Cobra Window Application.exe" -minimize -importResource obj\Debug\FEZ_Cobra_Window_Application1.Resources.tinyresources -compile "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\le\FEZ Cobra Window Application.pe"
GenerateStubs:
Creating directory "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\Stubs\".
C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Tools\MetaDataProcessor.exe -load "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\le\FEZ Cobra Window Application.pe" -load "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Graphics.pe" -load "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.pe" -load "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.pe" -load "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.TinyCore.pe" -load "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.pe" -load "C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\LE\FEZCobra_GHIElectronics.NETMF.FEZ.pe" -resolve -verbose -generate_skeleton "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\Stubs\FEZ Cobra Window Application" FEZ Cobra Window Application FEZ Cobra Window Application -refresh_assembly FEZ Cobra Window Application "C:\Users\Andrew Capon\AppData\Local\Temporary Projects\FEZ Cobra Window Application1\obj\Debug\le\FEZ Cobra Window Application.pe"
MMP : error MMP0000: 0xfd000000
Build FAILED.
Time Elapsed 00:00:00.50
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
========== Deploy: 0 succeeded, 0 failed, 0 skipped ==========
Anyone any ideas?
Cheers
Andy
