New Board DragonBoard 410c
New Board Qualcomm® DragonBoard 410c
Price about 75$ coming in summer 2015
OS Support:
Android 5.1 (Lollipop) on Linux Kernel 3.10 , Linaro Linux release based on current Linux kernel and Ubuntu, and Windows 10
CPU: quad-core ARM® Cortex® A53 at up to 1.2 GHz per core, 32-bit and 64-Bit capable
Memory/storage: 1Gb LPDDR3 533MHz/8 Gb eMMC 4.51/SD 3.0 (UHS-I)
Graphics: Qualcomm Adreno 306 400MHz GPU for PC-class graphics
Video: 1080p HD video playback and capture with H.264 (AVC)
Camera support: support for 13 megapixel camera with Wavelet Noise Reduction, JPEG decoder, and other post-processing techniques done in hardware
Connectivity and Location: Connectivity - integrated 802.11 b/g/n, BTS
Wi-Fi 802.11a/b/g/n 2.4GHz
Bluetooth 4.0
On-board BT and Wi-Fi antenna
GPS
On-board GPS antenna
I/O Interfaces: HDMI Full-size Type A connector (1080p HD @ 30fps), one micro USB (device mode only), two USB 2.0 type A (host mode only), micro SD card slot. Note: Micro USB (device mode) and USB 2.0 (host mode) are mutually exclusive and cannot be operated at the same time.
Expansion:
One 40 pin low speed expansion connector: UART, SPI, I2S, I2C x2, GPIO x12, DC power
One 60 pin high speed expansion connector: 4L-MIPI DSI, USB, I2C x2, 2L+4LMIPI CSI
Footprint for one optional 16 pin analog expansion connector for stereo headset/line-out, speaker and analog line-in
The board can be made compatible with Arduino using an add-on mezzanine board
Looks not bad.
GPS on Board, like to build a robot 8)
Things are hotting up in the ioT hardware scene. :clap:
