How long should the Enable function take to complete and return? It is taking around 20 seconds on my board to return and in the meantime, the other tasks are blocked.
The WiFi module returns the version so hardware-wise, it is communicating at the physical layer.
One thing that makes development difficult is that once the network is enabled, the debugging becomes impossible and hangs if I try to single step the code.
Nope. I have 2 threads for serial communicatons and both of them block until the call to Enable returns. Enable is being called from it’s own thread too.
Hello guys, I’m facing the same issue. I need to keep kicking a watchdog but the enabled function block all the threads and the watchdog triggers turning off the board…
Any workaround that you find to make it not blocking?
