NETMF SDK.exe needed
I have a problem when I want install GHI Electronics NETMF SDK 2015 R1 Pre-Release 2.
After to have clicked to “install”, it tell me to open “NETMF SDK.exe”.
Why ? I have installed all file needed :’(.
Thank you in advance for your help.
Micka
So, I progress :).
I have found the exe in tempory folder (.ba1).
But when I select it, I have this error :
[quote][080C:211C][2015-06-06T14:36:08]w341: Prompt for source of container: WixAttachedContainer, path: C:\NETMF SDK.exe
[080C:211C][2015-06-06T14:36:29]i336: Acquiring container: WixAttachedContainer, copy from: C:\Users\MyUserName\AppData\Local\Temp{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}.be\NETMF SDK.exe
[080C:211C][2015-06-06T14:36:29]i000: Setting string variable ‘WixBundleLastUsedSource’ to value ‘C:\Users\MyUserName\AppData\Local\Temp{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}.be’
[080C:1214][2015-06-06T14:36:29]e000: Error 0x80070001: Failed to extract all files from container, erf: 1:2:0
[080C:211C][2015-06-06T14:36:29]e000: Error 0x80070001: Failed to wait for operation complete.
[080C:211C][2015-06-06T14:36:29]e000: Error 0x80070001: Failed to open container.
[080C:211C][2015-06-06T14:36:29]e000: Error 0x80070001: Failed to open container: WixAttachedContainer.
[080C:211C][2015-06-06T14:36:29]e312: Failed to extract payloads from container: WixAttachedContainer to working path: C:\Users\MyUserName\AppData\Local\Temp{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}\17CA1E108937823E743696D2B7110A8537619EE7, error: 0x80070001.[/quote]
@ Micka - did you go through the steps and installed netmf first? Both netmf installers?
@ Gus - I am having the same issue on only 1 of 3 PCs I have tried. No issues on the other two. I am prompted for the file location for NETMF SDK.exe. Prior to this, in the advanced options I deselected support for 4.2. Are you saying that both 4.2 and 4.3 SDKs must be installed?
I have verified that Microsoft .NET Micro Framework 4.3 (QFE2) is correctly installed, and that netmfvs2013.vsix are installed. I am using VS2013 pro, with Win7/64.
Here is the log:
[3620:3A3C][2015-06-10T11:04:20]i001: Burn v3.9.1208.0, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\rocky.BSI_DOMAIN\Downloads\GHI Electronics NETMF SDK 2015 R1 Pre-Release 2.exe, cmdline: '-burn.unelevated BurnPipe.{8437B942-E48C-4468-A169-0B97054B7C7A} {0F5C1A2F-D1C9-422B-8501-D2A41FCC472D} 17168 ‘
[3620:3A3C][2015-06-10T11:04:20]i000: Initializing string variable ‘InstallFolder’ to value ‘[ProgramFilesFolder]GHI Electronics’
[3620:3A3C][2015-06-10T11:04:20]i000: Initializing numeric variable ‘STLoaderInstall’ to value ‘1’
[3620:3A3C][2015-06-10T11:04:20]i000: Initializing numeric variable ‘AtmelLoaderInstall’ to value ‘1’
[3620:3A3C][2015-06-10T11:04:20]i000: Initializing numeric variable ‘GHINETMF42Install’ to value ‘1’
[3620:3A3C][2015-06-10T11:04:20]i000: Initializing numeric variable ‘GHINETMF43Install’ to value ‘1’
[3620:3A3C][2015-06-10T11:04:20]i000: Initializing numeric variable ‘GHIGadgeteerInstall’ to value ‘1’
[3620:3A3C][2015-06-10T11:04:20]i000: Initializing numeric variable ‘FEZConfigInstall’ to value ‘1’
[3620:3A3C][2015-06-10T11:04:20]i000: Initializing numeric variable ‘USBDriversInstall’ to value ‘1’
[3620:3A3C][2015-06-10T11:04:23]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610110423.log’
[3620:3A3C][2015-06-10T11:04:23]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\Users\rocky.BSI_DOMAIN\Downloads\GHI Electronics NETMF SDK 2015 R1 Pre-Release 2.exe’
[3620:3A3C][2015-06-10T11:04:23]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value ‘C:\Users\rocky.BSI_DOMAIN\Downloads’
[3620:3A3C][2015-06-10T11:04:23]i052: Condition ‘VersionNT >= v6.1’ evaluates to true.
[3620:3A3C][2015-06-10T11:04:23]i000: Setting string variable ‘WixBundleName’ to value ‘GHI Electronics NETMF SDK 2015 R1 Pre-Release 2’
[3620:05B4][2015-06-10T11:04:23]i000: Setting version variable ‘WixBundleFileVersion’ to value ‘2015.1.8.0’
[3620:3A3C][2015-06-10T11:04:23]i100: Detect begin, 9 packages
[3620:3A3C][2015-06-10T11:04:23]i000: Setting version variable ‘STLoaderExists’ to value ‘3.0.2.0’
[3620:3A3C][2015-06-10T11:04:23]i000: Setting numeric variable ‘AtmelLoaderExists’ to value 1
[3620:3A3C][2015-06-10T11:04:23]i052: Condition ‘AtmelLoaderExists’ evaluates to true.
[3620:3A3C][2015-06-10T11:04:23]i052: Condition ‘STLoaderExists’ evaluates to true.
[3620:3A3C][2015-06-10T11:04:23]i101: Detected package: sam_ba.2.12.exe, state: Present, cached: Complete
[3620:3A3C][2015-06-10T11:04:23]i101: Detected package: DfuSe_Demo_V3.0.3_Setup.exe, state: Present, cached: None
[3620:3A3C][2015-06-10T11:04:23]i101: Detected package: DfuSe_Demo_V3.0.3_Setup_amd64.exe, state: Present, cached: Complete
[3620:3A3C][2015-06-10T11:04:23]i101: Detected package: NETMF_v4.2_SDK.msi, state: Absent, cached: None
[3620:3A3C][2015-06-10T11:04:23]i101: Detected package: NETMF_v4.3_SDK.msi, state: Absent, cached: None
[3620:3A3C][2015-06-10T11:04:23]i101: Detected package: .NET_Gadgeteer_SDK.msi, state: Absent, cached: None
[3620:3A3C][2015-06-10T11:04:23]i101: Detected package: FEZ_Config.msi, state: Absent, cached: None
[3620:3A3C][2015-06-10T11:04:23]i101: Detected package: USB_Drivers_x86.msi, state: Absent, cached: None
[3620:3A3C][2015-06-10T11:04:23]i101: Detected package: USB_Drivers_x64.msi, state: Absent, cached: None
[3620:3A3C][2015-06-10T11:04:23]i199: Detect complete, result: 0x0
[3620:05B4][2015-06-10T11:04:28]i000: Setting numeric variable ‘EulaAcceptCheckbox’ to value 1
[3620:05B4][2015-06-10T11:04:39]i000: Setting string variable ‘InstallFolder’ to value ‘C:\Program Files (x86)\GHI Electronics’
[3620:05B4][2015-06-10T11:04:39]i000: Setting numeric variable ‘STLoaderInstall’ to value 1
[3620:05B4][2015-06-10T11:04:39]i000: Setting numeric variable ‘AtmelLoaderInstall’ to value 1
[3620:05B4][2015-06-10T11:04:39]i000: Setting numeric variable ‘GHINETMF42Install’ to value 0
[3620:05B4][2015-06-10T11:04:39]i000: Setting numeric variable ‘GHINETMF43Install’ to value 1
[3620:05B4][2015-06-10T11:04:39]i000: Setting numeric variable ‘GHIGadgeteerInstall’ to value 1
[3620:05B4][2015-06-10T11:04:39]i000: Setting numeric variable ‘FEZConfigInstall’ to value 1
[3620:05B4][2015-06-10T11:04:39]i000: Setting numeric variable ‘USBDriversInstall’ to value 1
[3620:05B4][2015-06-10T11:04:43]i000: Setting numeric variable ‘EulaAcceptCheckbox’ to value 1
[3620:3A3C][2015-06-10T11:04:43]i200: Plan begin, 9 packages, action: Install
[3620:3A3C][2015-06-10T11:04:43]i052: Condition ‘AtmelLoaderInstall’ evaluates to true.
[3620:3A3C][2015-06-10T11:04:43]w321: Skipping dependency registration on package with no dependency providers: sam_ba.2.12.exe
[3620:3A3C][2015-06-10T11:04:43]i052: Condition ‘STLoaderInstall AND NOT VersionNT64’ evaluates to false.
[3620:3A3C][2015-06-10T11:04:43]w321: Skipping dependency registration on package with no dependency providers: DfuSe_Demo_V3.0.3_Setup.exe
[3620:3A3C][2015-06-10T11:04:43]i052: Condition ‘STLoaderInstall AND VersionNT64’ evaluates to true.
[3620:3A3C][2015-06-10T11:04:43]w321: Skipping dependency registration on package with no dependency providers: DfuSe_Demo_V3.0.3_Setup_amd64.exe
[3620:3A3C][2015-06-10T11:04:43]i052: Condition ‘GHINETMF42Install’ evaluates to false.
[3620:3A3C][2015-06-10T11:04:43]i052: Condition ‘GHINETMF43Install’ evaluates to true.
[3620:3A3C][2015-06-10T11:04:43]i000: Setting string variable ‘WixBundleRollbackLog_NETMF_v4.3_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610110423_0_NETMF_v4.3_SDK.msi_rollback.log’
[3620:3A3C][2015-06-10T11:04:43]i000: Setting string variable ‘WixBundleLog_NETMF_v4.3_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610110423_0_NETMF_v4.3_SDK.msi.log’
[3620:3A3C][2015-06-10T11:04:43]i052: Condition ‘GHIGadgeteerInstall’ evaluates to true.
[3620:3A3C][2015-06-10T11:04:43]i000: Setting string variable 'WixBundleRollbackLog
_.NET_Gadgeteer_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610110423_1__.NET_Gadgeteer_SDK.msi_rollback.log’
[3620:3A3C][2015-06-10T11:04:43]i000: Setting string variable ‘WixBundleLog__.NET_Gadgeteer_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610110423_1__.NET_Gadgeteer_SDK.msi.log’
[3620:3A3C][2015-06-10T11:04:43]i052: Condition ‘FEZConfigInstall’ evaluates to true.
[3620:3A3C][2015-06-10T11:04:43]i000: Setting string variable ‘WixBundleRollbackLog_FEZ_Config.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610110423_2_FEZ_Config.msi_rollback.log’
[3620:3A3C][2015-06-10T11:04:43]i000: Setting string variable ‘WixBundleLog_FEZ_Config.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610110423_2_FEZ_Config.msi.log’
[3620:3A3C][2015-06-10T11:04:43]i052: Condition ‘USBDriversInstall AND NOT VersionNT64’ evaluates to false.
[3620:3A3C][2015-06-10T11:04:43]i052: Condition ‘USBDriversInstall AND VersionNT64’ evaluates to true.
[3620:3A3C][2015-06-10T11:04:43]i000: Setting string variable ‘WixBundleRollbackLog_USB_Drivers_x64.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610110423_3_USB_Drivers_x64.msi_rollback.log’
[3620:3A3C][2015-06-10T11:04:43]i000: Setting string variable ‘WixBundleLog_USB_Drivers_x64.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610110423_3_USB_Drivers_x64.msi.log’
[3620:3A3C][2015-06-10T11:04:43]i201: Planned package: sam_ba.2.12.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3620:3A3C][2015-06-10T11:04:43]i201: Planned package: DfuSe_Demo_V3.0.3_Setup.exe, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3620:3A3C][2015-06-10T11:04:43]i201: Planned package: DfuSe_Demo_V3.0.3_Setup_amd64.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3620:3A3C][2015-06-10T11:04:43]i201: Planned package: NETMF_v4.2_SDK.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3620:3A3C][2015-06-10T11:04:43]i201: Planned package: NETMF_v4.3_SDK.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[3620:3A3C][2015-06-10T11:04:43]i201: Planned package: _.NET_Gadgeteer_SDK.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[3620:3A3C][2015-06-10T11:04:43]i201: Planned package: FEZ_Config.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[3620:3A3C][2015-06-10T11:04:43]i201: Planned package: USB_Drivers_x86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3620:3A3C][2015-06-10T11:04:43]i201: Planned package: USB_Drivers_x64.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[3620:3A3C][2015-06-10T11:04:43]i299: Plan complete, result: 0x0
[3620:3A3C][2015-06-10T11:04:43]i300: Apply begin
[4310:3FB8][2015-06-10T11:04:44]i360: Creating a system restore point.
[4310:3FB8][2015-06-10T11:06:18]i361: Created a system restore point.
[4310:3FB8][2015-06-10T11:06:20]i000: Caching bundle from: ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}.be\NETMF SDK.exe’ to: ‘C:\ProgramData\Package Cache{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}\NETMF SDK.exe’
[4310:3FB8][2015-06-10T11:06:20]i320: Registering bundle dependency provider: {d77f517c-3c36-4b39-af30-fa64aeeb8dd8}, version: 2015.1.8.0
[3620:10F4][2015-06-10T11:06:20]w341: Prompt for source of container: WixAttachedContainer, path: C:\Users\rocky.BSI_DOMAIN\Downloads\NETMF SDK.exe
[3620:10F4][2015-06-10T11:06:37]e054: Failed to resolve source for file: C:\Users\rocky.BSI_DOMAIN\Downloads\NETMF SDK.exe, error: 0x80070642.
[3620:10F4][2015-06-10T11:06:37]e000: Error 0x80070642: Failed while prompting for source (original path ‘C:\Users\rocky.BSI_DOMAIN\Downloads\NETMF SDK.exe’).
[3620:10F4][2015-06-10T11:06:37]e311: Failed to acquire container: WixAttachedContainer to working path: C:\Users\ROCKY~1.BSI\AppData\Local\Temp{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}\17CA1E108937823E743696D2B7110A8537619EE7, error: 0x80070642.
[3620:3A3C][2015-06-10T11:06:49]e000: Error 0x80070642: Failed while caching, aborting execution.
[4310:3FB8][2015-06-10T11:06:49]i330: Removed bundle dependency provider: {d77f517c-3c36-4b39-af30-fa64aeeb8dd8}
[4310:3FB8][2015-06-10T11:06:49]i352: Removing cached bundle: {d77f517c-3c36-4b39-af30-fa64aeeb8dd8}, from path: C:\ProgramData\Package Cache{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}
[3620:3A3C][2015-06-10T11:06:49]i399: Apply complete, result: 0x80070642, restart: None, ba requested restart: No
@ rockybooth - If you rename the installer to NETMF SDK.exe, does it work?
@ John:
Rename GHI Electronics NETMF SDK 2015 R1 Pre-Release 2.exe to NETMF SDK.exe.
Run NETMF SDK.exe, setup FAILED
Here is the log:
[3A54:3BC4][2015-06-10T11:33:38]i001: Burn v3.9.1208.0, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\rocky.BSI_DOMAIN\Downloads\NETMF SDK.exe, cmdline: '-burn.unelevated BurnPipe.{21E2A734-40E0-438D-9AEE-602299ED90BC} {F5C13107-7FF5-424A-9FE4-6B6E9A5D7607} 10744 ‘
[3A54:3BC4][2015-06-10T11:33:38]i000: Initializing string variable ‘InstallFolder’ to value ‘[ProgramFilesFolder]GHI Electronics’
[3A54:3BC4][2015-06-10T11:33:38]i000: Initializing numeric variable ‘STLoaderInstall’ to value ‘1’
[3A54:3BC4][2015-06-10T11:33:38]i000: Initializing numeric variable ‘AtmelLoaderInstall’ to value ‘1’
[3A54:3BC4][2015-06-10T11:33:38]i000: Initializing numeric variable ‘GHINETMF42Install’ to value ‘1’
[3A54:3BC4][2015-06-10T11:33:38]i000: Initializing numeric variable ‘GHINETMF43Install’ to value ‘1’
[3A54:3BC4][2015-06-10T11:33:38]i000: Initializing numeric variable ‘GHIGadgeteerInstall’ to value ‘1’
[3A54:3BC4][2015-06-10T11:33:38]i000: Initializing numeric variable ‘FEZConfigInstall’ to value ‘1’
[3A54:3BC4][2015-06-10T11:33:38]i000: Initializing numeric variable ‘USBDriversInstall’ to value ‘1’
[3A54:3BC4][2015-06-10T11:33:38]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610113338.log’
[3A54:3BC4][2015-06-10T11:33:38]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\Users\rocky.BSI_DOMAIN\Downloads\NETMF SDK.exe’
[3A54:3BC4][2015-06-10T11:33:38]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value ‘C:\Users\rocky.BSI_DOMAIN\Downloads’
[3A54:3BC4][2015-06-10T11:33:39]i052: Condition ‘VersionNT >= v6.1’ evaluates to true.
[3A54:3BC4][2015-06-10T11:33:39]i000: Setting string variable ‘WixBundleName’ to value ‘GHI Electronics NETMF SDK 2015 R1 Pre-Release 2’
[3A54:2470][2015-06-10T11:33:39]i000: Setting version variable ‘WixBundleFileVersion’ to value ‘2015.1.8.0’
[3A54:3BC4][2015-06-10T11:33:39]i100: Detect begin, 9 packages
[3A54:3BC4][2015-06-10T11:33:39]i000: Setting version variable ‘STLoaderExists’ to value ‘3.0.2.0’
[3A54:3BC4][2015-06-10T11:33:39]i000: Setting numeric variable ‘AtmelLoaderExists’ to value 1
[3A54:3BC4][2015-06-10T11:33:39]i052: Condition ‘AtmelLoaderExists’ evaluates to true.
[3A54:3BC4][2015-06-10T11:33:39]i052: Condition ‘STLoaderExists’ evaluates to true.
[3A54:3BC4][2015-06-10T11:33:39]i101: Detected package: sam_ba.2.12.exe, state: Present, cached: Complete
[3A54:3BC4][2015-06-10T11:33:39]i101: Detected package: DfuSe_Demo_V3.0.3_Setup.exe, state: Present, cached: None
[3A54:3BC4][2015-06-10T11:33:39]i101: Detected package: DfuSe_Demo_V3.0.3_Setup_amd64.exe, state: Present, cached: Complete
[3A54:3BC4][2015-06-10T11:33:39]i101: Detected package: NETMF_v4.2_SDK.msi, state: Absent, cached: None
[3A54:3BC4][2015-06-10T11:33:39]i101: Detected package: NETMF_v4.3_SDK.msi, state: Absent, cached: None
[3A54:3BC4][2015-06-10T11:33:39]i101: Detected package: .NET_Gadgeteer_SDK.msi, state: Absent, cached: None
[3A54:3BC4][2015-06-10T11:33:39]i101: Detected package: FEZ_Config.msi, state: Absent, cached: None
[3A54:3BC4][2015-06-10T11:33:39]i101: Detected package: USB_Drivers_x86.msi, state: Absent, cached: None
[3A54:3BC4][2015-06-10T11:33:39]i101: Detected package: USB_Drivers_x64.msi, state: Absent, cached: None
[3A54:3BC4][2015-06-10T11:33:39]i199: Detect complete, result: 0x0
[3A54:2470][2015-06-10T11:33:43]i000: Setting numeric variable ‘EulaAcceptCheckbox’ to value 1
[3A54:2470][2015-06-10T11:33:48]i000: Setting string variable ‘InstallFolder’ to value ‘C:\Program Files (x86)\GHI Electronics’
[3A54:2470][2015-06-10T11:33:48]i000: Setting numeric variable ‘STLoaderInstall’ to value 1
[3A54:2470][2015-06-10T11:33:48]i000: Setting numeric variable ‘AtmelLoaderInstall’ to value 1
[3A54:2470][2015-06-10T11:33:48]i000: Setting numeric variable ‘GHINETMF42Install’ to value 0
[3A54:2470][2015-06-10T11:33:48]i000: Setting numeric variable ‘GHINETMF43Install’ to value 1
[3A54:2470][2015-06-10T11:33:48]i000: Setting numeric variable ‘GHIGadgeteerInstall’ to value 1
[3A54:2470][2015-06-10T11:33:48]i000: Setting numeric variable ‘FEZConfigInstall’ to value 1
[3A54:2470][2015-06-10T11:33:48]i000: Setting numeric variable ‘USBDriversInstall’ to value 1
[3A54:2470][2015-06-10T11:33:50]i000: Setting numeric variable ‘EulaAcceptCheckbox’ to value 1
[3A54:3BC4][2015-06-10T11:33:50]i200: Plan begin, 9 packages, action: Install
[3A54:3BC4][2015-06-10T11:33:50]i052: Condition ‘AtmelLoaderInstall’ evaluates to true.
[3A54:3BC4][2015-06-10T11:33:50]w321: Skipping dependency registration on package with no dependency providers: sam_ba.2.12.exe
[3A54:3BC4][2015-06-10T11:33:50]i052: Condition ‘STLoaderInstall AND NOT VersionNT64’ evaluates to false.
[3A54:3BC4][2015-06-10T11:33:50]w321: Skipping dependency registration on package with no dependency providers: DfuSe_Demo_V3.0.3_Setup.exe
[3A54:3BC4][2015-06-10T11:33:50]i052: Condition ‘STLoaderInstall AND VersionNT64’ evaluates to true.
[3A54:3BC4][2015-06-10T11:33:50]w321: Skipping dependency registration on package with no dependency providers: DfuSe_Demo_V3.0.3_Setup_amd64.exe
[3A54:3BC4][2015-06-10T11:33:50]i052: Condition ‘GHINETMF42Install’ evaluates to false.
[3A54:3BC4][2015-06-10T11:33:50]i052: Condition ‘GHINETMF43Install’ evaluates to true.
[3A54:3BC4][2015-06-10T11:33:50]i000: Setting string variable ‘WixBundleRollbackLog_NETMF_v4.3_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610113338_0_NETMF_v4.3_SDK.msi_rollback.log’
[3A54:3BC4][2015-06-10T11:33:50]i000: Setting string variable ‘WixBundleLog_NETMF_v4.3_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610113338_0_NETMF_v4.3_SDK.msi.log’
[3A54:3BC4][2015-06-10T11:33:50]i052: Condition ‘GHIGadgeteerInstall’ evaluates to true.
[3A54:3BC4][2015-06-10T11:33:50]i000: Setting string variable 'WixBundleRollbackLog
_.NET_Gadgeteer_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610113338_1__.NET_Gadgeteer_SDK.msi_rollback.log’
[3A54:3BC4][2015-06-10T11:33:50]i000: Setting string variable ‘WixBundleLog__.NET_Gadgeteer_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610113338_1__.NET_Gadgeteer_SDK.msi.log’
[3A54:3BC4][2015-06-10T11:33:50]i052: Condition ‘FEZConfigInstall’ evaluates to true.
[3A54:3BC4][2015-06-10T11:33:50]i000: Setting string variable ‘WixBundleRollbackLog_FEZ_Config.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610113338_2_FEZ_Config.msi_rollback.log’
[3A54:3BC4][2015-06-10T11:33:50]i000: Setting string variable ‘WixBundleLog_FEZ_Config.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610113338_2_FEZ_Config.msi.log’
[3A54:3BC4][2015-06-10T11:33:50]i052: Condition ‘USBDriversInstall AND NOT VersionNT64’ evaluates to false.
[3A54:3BC4][2015-06-10T11:33:50]i052: Condition ‘USBDriversInstall AND VersionNT64’ evaluates to true.
[3A54:3BC4][2015-06-10T11:33:50]i000: Setting string variable ‘WixBundleRollbackLog_USB_Drivers_x64.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610113338_3_USB_Drivers_x64.msi_rollback.log’
[3A54:3BC4][2015-06-10T11:33:50]i000: Setting string variable ‘WixBundleLog_USB_Drivers_x64.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610113338_3_USB_Drivers_x64.msi.log’
[3A54:3BC4][2015-06-10T11:33:50]i201: Planned package: sam_ba.2.12.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3A54:3BC4][2015-06-10T11:33:50]i201: Planned package: DfuSe_Demo_V3.0.3_Setup.exe, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3A54:3BC4][2015-06-10T11:33:50]i201: Planned package: DfuSe_Demo_V3.0.3_Setup_amd64.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3A54:3BC4][2015-06-10T11:33:50]i201: Planned package: NETMF_v4.2_SDK.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3A54:3BC4][2015-06-10T11:33:50]i201: Planned package: NETMF_v4.3_SDK.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[3A54:3BC4][2015-06-10T11:33:50]i201: Planned package: _.NET_Gadgeteer_SDK.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[3A54:3BC4][2015-06-10T11:33:50]i201: Planned package: FEZ_Config.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[3A54:3BC4][2015-06-10T11:33:50]i201: Planned package: USB_Drivers_x86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3A54:3BC4][2015-06-10T11:33:50]i201: Planned package: USB_Drivers_x64.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[3A54:3BC4][2015-06-10T11:33:50]i299: Plan complete, result: 0x0
[3A54:3BC4][2015-06-10T11:33:50]i300: Apply begin
[29F8:42C4][2015-06-10T11:33:50]i360: Creating a system restore point.
[29F8:42C4][2015-06-10T11:34:01]i361: Created a system restore point.
[29F8:42C4][2015-06-10T11:34:01]i000: Caching bundle from: ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}.be\NETMF SDK.exe’ to: ‘C:\ProgramData\Package Cache{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}\NETMF SDK.exe’
[29F8:42C4][2015-06-10T11:34:01]i320: Registering bundle dependency provider: {d77f517c-3c36-4b39-af30-fa64aeeb8dd8}, version: 2015.1.8.0
[3A54:4180][2015-06-10T11:34:01]i336: Acquiring container: WixAttachedContainer, copy from: C:\Users\rocky.BSI_DOMAIN\Downloads\NETMF SDK.exe
[3A54:4180][2015-06-10T11:34:02]i000: Setting string variable ‘WixBundleLastUsedSource’ to value ‘C:\Users\rocky.BSI_DOMAIN\Downloads’
[3A54:2430][2015-06-10T11:34:02]e000: Error 0x80070570: Failed to extract all files from container, erf: 1:4:0
[3A54:4180][2015-06-10T11:34:02]e000: Error 0x80070570: Failed to begin and wait for operation.
[3A54:4180][2015-06-10T11:34:02]e000: Error 0x80070570: Failed to extract payload: a1 from container: WixAttachedContainer
[3A54:4180][2015-06-10T11:34:02]e312: Failed to extract payloads from container: WixAttachedContainer to working path: C:\Users\ROCKY~1.BSI\AppData\Local\Temp{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}\17CA1E108937823E743696D2B7110A8537619EE7, error: 0x80070570.
[3A54:3BC4][2015-06-10T11:34:02]e000: Error 0x80070570: Failed while caching, aborting execution.
[29F8:42C4][2015-06-10T11:34:02]i330: Removed bundle dependency provider: {d77f517c-3c36-4b39-af30-fa64aeeb8dd8}
[29F8:42C4][2015-06-10T11:34:02]i352: Removing cached bundle: {d77f517c-3c36-4b39-af30-fa64aeeb8dd8}, from path: C:\ProgramData\Package Cache{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}
[3A54:3BC4][2015-06-10T11:34:02]i399: Apply complete, result: 0x80070570, restart: None, ba requested restart: No
@ rockybooth - In the log I see “BSI_DOMAIN” as part of the install path. Is your user profile by any chance mapped to some network drive, maybe through Active Directory? If you copy the installer to the desktop does it work? If not, how about the root of C:? Can you try running it as an administrator?
@ John:
Move renamed installer NETMF SDK.exe to desktop, launch as administrator: Setup Failed.
Move NETMF SDK.exe to C:, run as Administrator. Setup Failed. log follows:
[242C:0E20][2015-06-10T11:42:43]i001: Burn v3.9.1208.0, Windows v6.1 (Build 7601: Service Pack 1), path: C:\NETMF SDK.exe, cmdline: '-burn.unelevated BurnPipe.{7F2DC2F6-A172-4E84-8645-A77E65604766} {F9B44EA6-3A40-4F7A-B907-227FBA40F8E1} 1408 ‘
[242C:0E20][2015-06-10T11:42:43]i000: Initializing string variable ‘InstallFolder’ to value ‘[ProgramFilesFolder]GHI Electronics’
[242C:0E20][2015-06-10T11:42:43]i000: Initializing numeric variable ‘STLoaderInstall’ to value ‘1’
[242C:0E20][2015-06-10T11:42:43]i000: Initializing numeric variable ‘AtmelLoaderInstall’ to value ‘1’
[242C:0E20][2015-06-10T11:42:43]i000: Initializing numeric variable ‘GHINETMF42Install’ to value ‘1’
[242C:0E20][2015-06-10T11:42:43]i000: Initializing numeric variable ‘GHINETMF43Install’ to value ‘1’
[242C:0E20][2015-06-10T11:42:43]i000: Initializing numeric variable ‘GHIGadgeteerInstall’ to value ‘1’
[242C:0E20][2015-06-10T11:42:43]i000: Initializing numeric variable ‘FEZConfigInstall’ to value ‘1’
[242C:0E20][2015-06-10T11:42:43]i000: Initializing numeric variable ‘USBDriversInstall’ to value ‘1’
[242C:0E20][2015-06-10T11:42:43]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610114243.log’
[242C:0E20][2015-06-10T11:42:43]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\NETMF SDK.exe’
[242C:0E20][2015-06-10T11:42:43]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value ‘C:’
[242C:0E20][2015-06-10T11:42:43]i052: Condition ‘VersionNT >= v6.1’ evaluates to true.
[242C:0E20][2015-06-10T11:42:43]i000: Setting string variable ‘WixBundleName’ to value ‘GHI Electronics NETMF SDK 2015 R1 Pre-Release 2’
[242C:3F4C][2015-06-10T11:42:43]i000: Setting version variable ‘WixBundleFileVersion’ to value ‘2015.1.8.0’
[242C:0E20][2015-06-10T11:42:43]i100: Detect begin, 9 packages
[242C:0E20][2015-06-10T11:42:43]i000: Setting version variable ‘STLoaderExists’ to value ‘3.0.2.0’
[242C:0E20][2015-06-10T11:42:43]i000: Setting numeric variable ‘AtmelLoaderExists’ to value 1
[242C:0E20][2015-06-10T11:42:43]i052: Condition ‘AtmelLoaderExists’ evaluates to true.
[242C:0E20][2015-06-10T11:42:43]i052: Condition ‘STLoaderExists’ evaluates to true.
[242C:0E20][2015-06-10T11:42:43]i101: Detected package: sam_ba.2.12.exe, state: Present, cached: Complete
[242C:0E20][2015-06-10T11:42:43]i101: Detected package: DfuSe_Demo_V3.0.3_Setup.exe, state: Present, cached: None
[242C:0E20][2015-06-10T11:42:43]i101: Detected package: DfuSe_Demo_V3.0.3_Setup_amd64.exe, state: Present, cached: Complete
[242C:0E20][2015-06-10T11:42:43]i101: Detected package: NETMF_v4.2_SDK.msi, state: Absent, cached: None
[242C:0E20][2015-06-10T11:42:43]i101: Detected package: NETMF_v4.3_SDK.msi, state: Absent, cached: None
[242C:0E20][2015-06-10T11:42:43]i101: Detected package: .NET_Gadgeteer_SDK.msi, state: Absent, cached: None
[242C:0E20][2015-06-10T11:42:43]i101: Detected package: FEZ_Config.msi, state: Absent, cached: None
[242C:0E20][2015-06-10T11:42:43]i101: Detected package: USB_Drivers_x86.msi, state: Absent, cached: None
[242C:0E20][2015-06-10T11:42:43]i101: Detected package: USB_Drivers_x64.msi, state: Absent, cached: None
[242C:0E20][2015-06-10T11:42:43]i199: Detect complete, result: 0x0
[242C:3F4C][2015-06-10T11:42:48]i000: Setting numeric variable ‘EulaAcceptCheckbox’ to value 1
[242C:3F4C][2015-06-10T11:42:54]i000: Setting string variable ‘InstallFolder’ to value ‘C:\Program Files (x86)\GHI Electronics’
[242C:3F4C][2015-06-10T11:42:54]i000: Setting numeric variable ‘STLoaderInstall’ to value 1
[242C:3F4C][2015-06-10T11:42:54]i000: Setting numeric variable ‘AtmelLoaderInstall’ to value 1
[242C:3F4C][2015-06-10T11:42:54]i000: Setting numeric variable ‘GHINETMF42Install’ to value 0
[242C:3F4C][2015-06-10T11:42:54]i000: Setting numeric variable ‘GHINETMF43Install’ to value 1
[242C:3F4C][2015-06-10T11:42:54]i000: Setting numeric variable ‘GHIGadgeteerInstall’ to value 1
[242C:3F4C][2015-06-10T11:42:54]i000: Setting numeric variable ‘FEZConfigInstall’ to value 1
[242C:3F4C][2015-06-10T11:42:54]i000: Setting numeric variable ‘USBDriversInstall’ to value 1
[242C:3F4C][2015-06-10T11:43:00]i000: Setting numeric variable ‘EulaAcceptCheckbox’ to value 1
[242C:0E20][2015-06-10T11:43:00]i200: Plan begin, 9 packages, action: Install
[242C:0E20][2015-06-10T11:43:00]i052: Condition ‘AtmelLoaderInstall’ evaluates to true.
[242C:0E20][2015-06-10T11:43:00]w321: Skipping dependency registration on package with no dependency providers: sam_ba.2.12.exe
[242C:0E20][2015-06-10T11:43:00]i052: Condition ‘STLoaderInstall AND NOT VersionNT64’ evaluates to false.
[242C:0E20][2015-06-10T11:43:00]w321: Skipping dependency registration on package with no dependency providers: DfuSe_Demo_V3.0.3_Setup.exe
[242C:0E20][2015-06-10T11:43:00]i052: Condition ‘STLoaderInstall AND VersionNT64’ evaluates to true.
[242C:0E20][2015-06-10T11:43:00]w321: Skipping dependency registration on package with no dependency providers: DfuSe_Demo_V3.0.3_Setup_amd64.exe
[242C:0E20][2015-06-10T11:43:00]i052: Condition ‘GHINETMF42Install’ evaluates to false.
[242C:0E20][2015-06-10T11:43:00]i052: Condition ‘GHINETMF43Install’ evaluates to true.
[242C:0E20][2015-06-10T11:43:00]i000: Setting string variable ‘WixBundleRollbackLog_NETMF_v4.3_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610114243_0_NETMF_v4.3_SDK.msi_rollback.log’
[242C:0E20][2015-06-10T11:43:00]i000: Setting string variable ‘WixBundleLog_NETMF_v4.3_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610114243_0_NETMF_v4.3_SDK.msi.log’
[242C:0E20][2015-06-10T11:43:00]i052: Condition ‘GHIGadgeteerInstall’ evaluates to true.
[242C:0E20][2015-06-10T11:43:00]i000: Setting string variable 'WixBundleRollbackLog
_.NET_Gadgeteer_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610114243_1__.NET_Gadgeteer_SDK.msi_rollback.log’
[242C:0E20][2015-06-10T11:43:00]i000: Setting string variable ‘WixBundleLog__.NET_Gadgeteer_SDK.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610114243_1__.NET_Gadgeteer_SDK.msi.log’
[242C:0E20][2015-06-10T11:43:00]i052: Condition ‘FEZConfigInstall’ evaluates to true.
[242C:0E20][2015-06-10T11:43:00]i000: Setting string variable ‘WixBundleRollbackLog_FEZ_Config.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610114243_2_FEZ_Config.msi_rollback.log’
[242C:0E20][2015-06-10T11:43:00]i000: Setting string variable ‘WixBundleLog_FEZ_Config.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610114243_2_FEZ_Config.msi.log’
[242C:0E20][2015-06-10T11:43:00]i052: Condition ‘USBDriversInstall AND NOT VersionNT64’ evaluates to false.
[242C:0E20][2015-06-10T11:43:00]i052: Condition ‘USBDriversInstall AND VersionNT64’ evaluates to true.
[242C:0E20][2015-06-10T11:43:00]i000: Setting string variable ‘WixBundleRollbackLog_USB_Drivers_x64.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610114243_3_USB_Drivers_x64.msi_rollback.log’
[242C:0E20][2015-06-10T11:43:00]i000: Setting string variable ‘WixBundleLog_USB_Drivers_x64.msi’ to value ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp\GHI_Electronics_NETMF_SDK_2015_R1_Pre-Release_2_20150610114243_3_USB_Drivers_x64.msi.log’
[242C:0E20][2015-06-10T11:43:00]i201: Planned package: sam_ba.2.12.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[242C:0E20][2015-06-10T11:43:00]i201: Planned package: DfuSe_Demo_V3.0.3_Setup.exe, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[242C:0E20][2015-06-10T11:43:00]i201: Planned package: DfuSe_Demo_V3.0.3_Setup_amd64.exe, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[242C:0E20][2015-06-10T11:43:00]i201: Planned package: NETMF_v4.2_SDK.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[242C:0E20][2015-06-10T11:43:00]i201: Planned package: NETMF_v4.3_SDK.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[242C:0E20][2015-06-10T11:43:00]i201: Planned package: _.NET_Gadgeteer_SDK.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[242C:0E20][2015-06-10T11:43:00]i201: Planned package: FEZ_Config.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[242C:0E20][2015-06-10T11:43:00]i201: Planned package: USB_Drivers_x86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[242C:0E20][2015-06-10T11:43:00]i201: Planned package: USB_Drivers_x64.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[242C:0E20][2015-06-10T11:43:00]i299: Plan complete, result: 0x0
[242C:0E20][2015-06-10T11:43:00]i300: Apply begin
[0580:3B4C][2015-06-10T11:43:00]i360: Creating a system restore point.
[0580:3B4C][2015-06-10T11:44:31]i361: Created a system restore point.
[0580:3B4C][2015-06-10T11:44:32]i000: Caching bundle from: ‘C:\Users\ROCKY~1.BSI\AppData\Local\Temp{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}.be\NETMF SDK.exe’ to: ‘C:\ProgramData\Package Cache{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}\NETMF SDK.exe’
[0580:3B4C][2015-06-10T11:44:32]i320: Registering bundle dependency provider: {d77f517c-3c36-4b39-af30-fa64aeeb8dd8}, version: 2015.1.8.0
[242C:1FCC][2015-06-10T11:44:32]i336: Acquiring container: WixAttachedContainer, copy from: C:\NETMF SDK.exe
[242C:1FCC][2015-06-10T11:44:33]i000: Setting string variable ‘WixBundleLastUsedSource’ to value ‘C:’
[242C:3970][2015-06-10T11:44:33]e000: Error 0x80070570: Failed to extract all files from container, erf: 1:4:0
[242C:1FCC][2015-06-10T11:44:33]e000: Error 0x80070570: Failed to begin and wait for operation.
[242C:1FCC][2015-06-10T11:44:33]e000: Error 0x80070570: Failed to extract payload: a1 from container: WixAttachedContainer
[242C:1FCC][2015-06-10T11:44:33]e312: Failed to extract payloads from container: WixAttachedContainer to working path: C:\Users\ROCKY~1.BSI\AppData\Local\Temp{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}\17CA1E108937823E743696D2B7110A8537619EE7, error: 0x80070570.
[242C:0E20][2015-06-10T11:44:33]e000: Error 0x80070570: Failed while caching, aborting execution.
[0580:3B4C][2015-06-10T11:44:33]i330: Removed bundle dependency provider: {d77f517c-3c36-4b39-af30-fa64aeeb8dd8}
[0580:3B4C][2015-06-10T11:44:33]i352: Removing cached bundle: {d77f517c-3c36-4b39-af30-fa64aeeb8dd8}, from path: C:\ProgramData\Package Cache{d77f517c-3c36-4b39-af30-fa64aeeb8dd8}
[242C:0E20][2015-06-10T11:44:33]i399: Apply complete, result: 0x80070570, restart: None, ba requested restart: No
@ rockybooth - Is your user profile directory mapped somewhere else or cached?
@ John: Not that I am aware of.
I just tried installing GHI Electronics NETMF SDK 2015 Pre-Release 1.exe, from the downloads directory, not using special Administrator rights, and it installed successfully. Not sure where to find the log, let me know and I will send it.
Rocky
@ rockybooth - Can you try redownloading the pre-release 2 SDK? After doing so, can you compute its MD5 hash?
@ John: It must have been a bad download. I checked the hash and it did not match, then downloaded a new copy and it matched, and worked!
at least I learned to compute a hash!
