When is the new GHI NETMF Package with power control support for G120 expected to be released?
(The issue with Hibernate and power levels)
Some may make it to the sdk coming shortly more in couple months.
Is it possible that you use the PowelLevel option in NETMF (enum = high, low, medium), that does nothing today, to set the CPU Clock divider to 1 (high), 3 (low), 2 (medium) as an example (with default 1)?
It will give some points!
Especially if the e.g. baud rates is corrected for this through this setting, too.
This could cut off 24 mA @ low, which is alot !
We will look into it.
