NET Microframework difference between be and le dll directory
it probably is a stupid question, but what is the difference between BE and LE folder in the directory of Microframework assemblies? What is the preferred library directory?
Thank you.
@ gremlinc5 - The BE is for big endian and the LE is for little endian.
Visual Studio loads the correct assemblies for you, depending upon the board you are using. After 5+ years using the micro framework, I don’t know which libraries are used with which boards. ;D
Sometimes VS 2013 doesn’t load usings correctly so I manually force them in my Projects… I will find in the datasheet if the GHI G400 is BE or LE so.
Thank you very much! :wink:
Debug.Print(BitConverter.IsLittleEndian.ToString());
I love this community!
Even with just a casual stroll through the forums, I often end up learning something completely new. :slight_smile:
Cheers it’s more simple that scroll all the datasheet :slight_smile:
