// Copyright GHI Electronics, LLC
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#pragma once
#define STM32F405xx 1
#include <STM32F4.h>
#define DEVICE_TARGET STM32F4
#define DEVICE_NAME "WioLTE"
#define DEVICE_MANUFACTURER "Seeed"
#define DEVICE_VERSION ((0ULL << 48) | (6ULL << 32) | (0ULL << 16) | (0ULL << 0))
#define DEVICE_MEMORY_PROFILE_FACTOR 7
#define USB_DEBUGGER_VENDOR_ID 0x1B9F
#define USB_DEBUGGER_PRODUCT_ID 0x5000
#define UART_DEBUGGER_INDEX 0
#define USB_DEBUGGER_INDEX 0
#define DEBUGGER_FORCE_API STM32F4_UsbDevice_GetRequiredApi()
#define DEBUGGER_FORCE_INDEX USB_DEBUGGER_INDEX
//add
#define DEBUGGER_SELECTOR_PIN PIN(B, 10)
#define DEBUGGER_SELECTOR_PULL TinyCLR_Gpio_PinDriveMode::InputPullUp
#define DEBUGGER_SELECTOR_USB_STATE TinyCLR_Gpio_PinValue::High
//add
//#define RUN_APP_PIN PIN(B, 7)
#define RUN_APP_PIN PIN(C, 13)
#define RUN_APP_PULL TinyCLR_Gpio_PinDriveMode::InputPullUp
#define RUN_APP_STATE TinyCLR_Gpio_PinValue::High
#define BOOTLOADER_HOLD_ADDRESS 0x20017FF8
#define BOOTLOADER_HOLD_VALUE 0x82469E42
#define DEPLOYMENT_SECTORS { { 0x06, 0x08040000, 0x00020000 }, { 0x07, 0x08060000, 0x00020000 }, { 0x08, 0x08080000, 0x00020000 }, { 0x09, 0x080A0000, 0x00020000 }, { 0x0A, 0x080C0000, 0x00020000 }, { 0x0B, 0x080E0000, 0x00020000 } }
#define STM32F4_SYSTEM_CLOCK_HZ 168000000
#define STM32F4_AHB_CLOCK_HZ 168000000
//#define STM32F4_SYSTEM_CLOCK_HZ 84000000
//#define STM32F4_AHB_CLOCK_HZ 84000000
#define STM32F4_APB1_CLOCK_HZ 42000000
#define STM32F4_APB2_CLOCK_HZ 84000000
#define STM32F4_EXT_CRYSTAL_CLOCK_HZ 8000000
#define STM32F4_SUPPLY_VOLTAGE_MV 3300
#define INCLUDE_ADC
#define INCLUDE_DEPLOYMENT
#define INCLUDE_GPIO
#define STM32F4_GPIO_PINS {/* 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 */\
/*PAx*/ DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(),\
/*PBx*/ DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(),\
/*PCx*/ DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(),\
/*PDx*/ DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT(), DEFAULT()\
#define INCLUDE_I2C
#define TOTAL_I2C_CONTROLLERS 1
//#define STM32F4_I2C_SCL_PINS { { PIN(B, 6), AF(4) } }
//#define STM32F4_I2C_SDA_PINS { { PIN(B, 7), AF(4) } }
#define STM32F4_I2C_PINS {/* SDA SCL*/ \
/*I2C0*/ { { PIN(B, 7), AF(4) }, { PIN(B, 6), AF(4) } }\
#define INCLUDE_POWER
#define INCLUDE_PWM
#define TOTAL_PWM_CONTROLLERS 4
#define STM32F4_PWM_PINS {/* 0 1 2 3 */\
/* TIM1 */ { { PIN(A, 8), AF(1) }, { PIN(A, 9), AF(1) }, { PIN(A, 10), AF(1) }, { PIN_NONE , AF_NONE } },\
/* TIM2 */ { { PIN(A, 0), AF(1) }, { PIN(A, 1), AF(1) }, { PIN(A, 2), AF(1) }, { PIN(A, 3), AF(1) } },\
/* TIM3 */ { { PIN(C, 6), AF(2) }, { PIN(C, 7), AF(2) }, { PIN(C, 8), AF(2) }, { PIN(C, 9), AF(2) } },\
/* TIM4 */ { { PIN(B, 7), AF(2) }, { PIN(B, 7), AF(2) }, { PIN(B, 8), AF(2) }, { PIN(B, 9), AF(2) } },\
#define INCLUDE_RTC
#define INCLUDE_SIGNALS
#define INCLUDE_SPI
#define TOTAL_SPI_CONTROLLERS 2
//#define STM32F4_SPI_SCLK_PINS { { PIN(B, 3), AF(5) }, { PIN(B, 13), AF(5) } }
//#define STM32F4_SPI_MISO_PINS { { PIN(B, 4), AF(5) }, { PIN(B, 14), AF(5) } }
//#define STM32F4_SPI_MOSI_PINS { { PIN(B, 5), AF(5) }, { PIN(B, 15), AF(5) } }
#define STM32F4_SPI_PINS {/* MOSI MISO CLOCK*/ \
/*SPI0*/{ { PIN(B, 5), AF(5) }, { PIN(B, 4), AF(5) }, { PIN(B, 3) , AF(5) } },\
/*SPI1*/{ { PIN(B, 15), AF(5) }, { PIN(B, 14), AF(5) }, { PIN(B, 13), AF(5) } } \
#define INCLUDE_STORAGE
#define INCLUDE_UART
#define TOTAL_UART_CONTROLLERS 2
#define STM32F4_UART_DEFAULT_TX_BUFFER_SIZE { 256, 256 }
#define STM32F4_UART_DEFAULT_RX_BUFFER_SIZE { 512, 512 }
//#define STM32F4_UART_TX_PINS { { PIN(B, 6), AF(7) }, { PIN(A, 2), AF(7) } }
//#define STM32F4_UART_RX_PINS { { PIN(B, 7), AF(7) }, { PIN(A, 3), AF(7) } }
//#define STM32F4_UART_CTS_PINS { { PIN_NONE, AF_NONE }, { PIN_NONE, AF_NONE } }
//#define STM32F4_UART_RTS_PINS { { PIN_NONE, AF_NONE }, { PIN_NONE, AF_NONE } }
#define STM32F4_UART_PINS {/* TX RX RTS CTS*/ \
/*UART0*/{ { PIN(B, 6), AF(7) }, { PIN(B, 7), AF(7) }, { PIN_NONE, AF_NONE }, { PIN_NONE, AF_NONE } },\
/*UART1*/{ { PIN(A, 2), AF(7) }, { PIN(A, 3), AF(7) }, { PIN_NONE, AF_NONE }, { PIN_NONE, AF_NONE } } \
#define INCLUDE_USBCLIENT
#define STM32F4_TOTAL_USB_CONTROLLERS 1
#define STM32F4_USB_PACKET_FIFO_COUNT 32
//#define STM32F4_USB_PACKET_FIFO_COUNT 16
#define STM32F4_USB_ENDPOINT_SIZE 64
#define STM32F4_USB_ENDPOINT0_SIZE 8
#define STM32F4_USB_ENDPOINT_COUNT 4
#define STM32F4_USB_PIPE_COUNT 4
//#define STM32F4_USB_DM_PINS { { PIN(A, 11), AF(10) } }
//#define STM32F4_USB_DP_PINS { { PIN(A, 12), AF(10) } }
//#define STM32F4_USB_VB_PINS { { PIN(A, 9), AF(10) } }
//#define STM32F4_USB_ID_PINS { { PIN(A, 10), AF(10) } }
#define STM32F4_USB_PINS {/* DM DP VB ID*/ \
/*USBC0*/{ { PIN(A, 11), AF(10) }, { PIN(A, 12), AF(10) }, { PIN(A, 9), AF(10) }, { PIN(A, 10), AF(10) } }\
I have changed some code, and it works…
I found missing interop in your Seeed.TinyCLR.WioLTE library… I cannot find the code…
[MethodImpl(MethodImplOptions.InternalCall)]
public static extern int slre_match(string regexp, string buf);
public static extern string slre_match2(string regexp, string buf);
public extern void Init();
public extern void LedSetRGB(byte r, byte g, byte b);
