I want to try out the RLP feature in DOMINO but everytime i add GHIElectronics.NETFM.Native even to a normal blink the led program i get the following error:
[quote]Rebooting…
Create TS.
Loading start at 4e54c, end 56724
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
AssemblyRef = 0 bytes ( 0 elements)
TypeRef = 0 bytes ( 0 elements)
FieldRef = 0 bytes ( 0 elements)
MethodRef = 0 bytes ( 0 elements)
TypeDef = 1112 bytes ( 139 elements)
FieldDef = 272 bytes ( 135 elements)
MethodDef = 1572 bytes ( 786 elements)
Attributes = 0 bytes ( 0 elements)
TypeSpec = 16 bytes ( 4 elements)
Resources = 232 bytes ( 29 elements)
Resources Files = 16 bytes ( 2 elements)
Resources Data = 437 bytes
Strings = 1551 bytes
Signatures = 2126 bytes
ByteCode = 11702 bytes
Attaching deployed file.
Assembly: Microsoft.SPOT.Graphics (4.1.2821.0) (388 RAM - 2268 ROM - 1357 METADATA)
AssemblyRef = 8 bytes ( 2 elements)
TypeRef = 24 bytes ( 6 elements)
MethodRef = 20 bytes ( 5 elements)
TypeDef = 40 bytes ( 5 elements)
FieldDef = 16 bytes ( 8 elements)
MethodDef = 96 bytes ( 48 elements)
TypeSpec = 0 bytes ( 0 elements)
Resources = 0 bytes ( 0 elements)
Resources Files = 0 bytes ( 0 elements)
Resources Data = 0 bytes
Strings = 537 bytes
Signatures = 293 bytes
ByteCode = 242 bytes
Assembly: GHIElectronics.NETMF.System (4.1.6.0) (488 RAM - 2496 ROM - 1465 METADATA)
AssemblyRef = 12 bytes ( 3 elements)
TypeRef = 48 bytes ( 12 elements)
MethodRef = 56 bytes ( 14 elements)
TypeDef = 80 bytes ( 10 elements)
FieldDef = 28 bytes ( 14 elements)
MethodDef = 84 bytes ( 41 elements)
Strings = 549 bytes
Signatures = 213 bytes
ByteCode = 349 bytes
Invalid native checksum: GHIElectronics.NETMF.System 0xC032A004!=0x74F83809
Assembly: LED_Matrix (1.0.0.0) (352 RAM - 2052 ROM - 761 METADATA)
TypeRef = 68 bytes ( 17 elements)
MethodRef = 44 bytes ( 11 elements)
TypeDef = 32 bytes ( 4 elements)
FieldDef = 16 bytes ( 7 elements)
MethodDef = 28 bytes ( 13 elements)
Resources = 16 bytes ( 2 elements)
Resources Files = 8 bytes ( 1 elements)
Resources Data = 13 bytes
Strings = 202 bytes
Signatures = 141 bytes
ByteCode = 902 bytes
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) (1752 RAM - 11440 ROM - 7371 METADATA)
TypeRef = 124 bytes ( 31 elements)
FieldRef = 24 bytes ( 6 elements)
MethodRef = 120 bytes ( 30 elements)
TypeDef = 496 bytes ( 62 elements)
FieldDef = 176 bytes ( 88 elements)
MethodDef = 444 bytes ( 222 elements)
Strings = 1329 bytes
Signatures = 1067 bytes
ByteCode = 2611 bytes
Resolving.
Assembly: Microsoft.SPOT.Graphics (4.1.2821.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Assembly: LED_Matrix (1.0.0.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Assembly: LED_Matrix (1.0.0.0) needs assembly ‘Microsoft.SPOT.Native’ (4.1.2821.0)
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) needs assembly ‘Microsoft.SPOT.Native’ (4.1.2821.0)
Error: a3000000
Waiting for debug commands…
The program ‘[5] Micro Framework application: Managed’ has exited with code 0 (0x0).
[/quote]
