Put a Thread.Sleep(100) inside your while(true) loop.
I think you have pins reversed. First is the trig pin.
Hi Architect this is the code file in Program.Generated.cs
// <auto-generated>
// This code was generated by the Gadgeteer Designer.
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
// </auto-generated>
using Gadgeteer;
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using GHI.Premium.Hardware;
using HC;
namespace GadgeteerApp1
public partial class Program : Gadgeteer.Program
// GTM.Module definitions
Gadgeteer.Modules.GHIElectronics.Extender extender;
Gadgeteer.Modules.GHIElectronics.UsbClientDP usbClientDP;
Gadgeteer.Modules.GHIElectronics.MotorControllerL298 motorControllerL298;
//Important to initialize the Mainboard first
Mainboard = new GHIElectronics.Gadgeteer.FEZSpider();
Program program = new Program();
program.InitializeModules();
program.ProgramStarted();
program.Run(); // Starts Dispatcher
HC_SR04 sensor = new HC_SR04(EMX.Pin.IO8, EMX.Pin.IO45);
long ticks = sensor.Ping();
Thread.Sleep(100);
if (ticks > 0L)
double inches = sensor.TicksToInches(ticks);
timer.Tick +=<tab><tab>
timer.Start();
private void InitializeModules()
// Initialize GTM.Modules and event handlers here.
usbClientDP = new GTM.GHIElectronics.UsbClientDP(1);
extender = new GTM.GHIElectronics.Extender(10);
motorControllerL298 = new GTM.GHIElectronics.MotorControllerL298(11);
This is the Program.cs file.
using Gadgeteer;
//using SecretLabs.NETMF.Hardware;
//using SecretLabs.NETMF.Hardware.Netduino;
namespace HC
public class HC_SR04
private OutputPort portOut;
private InterruptPort interIn;
private long beginTick;
private long endTick;
private long minTicks; // System latency, subtracted off ticks to find actual sound travel time
private double inchConversion;
private double version;
//Socket _socket;
/// <summary>
/// Constructor
/// </summary>
/// <param name="pinTrig">Netduino pin connected to the HC-SR04 Trig pin</param>
/// <param name="pinEcho">Netduino pin connected to the HC-SR04 Echo pin</param>
public HC_SR04(Cpu.Pin pinTrig, Cpu.Pin pinEcho)
// public HC_SR04(EMX.Pin pinTrig, EMX.Pin pinEcho)
portOut = new OutputPort(pinTrig, false);
interIn = new InterruptPort(pinEcho, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeLow);
interIn.OnInterrupt += new NativeEventHandler(interIn_OnInterrupt);
minTicks = 6200L;
inchConversion = 1440.0;
version = 1.1;
/// <summary>
/// Returns the library version number
/// </summary>
public double Version
get
return version;
/// <summary>
/// Trigger a sensor reading
/// Convert ticks to distance using TicksToInches below
/// </summary>
/// <returns>Number of ticks it takes to get back sonic pulse</returns>
public long Ping()
// Reset Sensor
portOut.Write(true);
Thread.Sleep(1);
// Start Clock
endTick = 0L;
beginTick = System.DateTime.Now.Ticks;
// Trigger Sonic Pulse
portOut.Write(false);
// Wait 1/20 second (this could be set as a variable instead of constant)
Thread.Sleep(50);
if (endTick > 0L)
// Calculate Difference
long elapsed = endTick - beginTick;
// Subtract out fixed overhead (interrupt lag, etc.)
elapsed -= minTicks;
if (elapsed < 0L)
elapsed = 0L;
// Return elapsed ticks
return elapsed;
// Sonic pulse wasn't detected within 1/20 second
return -1L;
/// <summary>
/// This interrupt will trigger when detector receives back reflected sonic pulse
/// </summary>
/// <param name="data1">Not used</param>
/// <param name="data2">Not used</param>
/// <param name="time">Transfer to endTick to calculated sound pulse travel time</param>
void interIn_OnInterrupt(uint data1, uint data2, DateTime time)
// Save the ticks when pulse was received back
endTick = time.Ticks;
/// <summary>
/// Convert ticks to inches
/// </summary>
/// <param name="ticks"></param>
/// <returns></returns>
public double TicksToInches(long ticks)
return (double)ticks / inchConversion;
/// <summary>
/// The ticks to inches conversion factor
/// </summary>
public double InchCoversionFactor
get
return inchConversion;
set
inchConversion = value;
/// <summary>
/// The system latency (minimum number of ticks)
/// This number will be subtracted off to find actual sound travel time
/// </summary>
public long LatencyTicks
get
return minTicks;
set
minTicks = value;
//public static void Main()
// //HC_SR04 sensor = new HC_SR04(Pins.GPIO_PIN_D6, Pins.GPIO_PIN_D7);
But the output is like this. What is the fault.
Using mainboard GHI Electronics FEZSpider version 1.0
Program Started
Ok, you are mixing Gadgeteer and non-Gadgeteer approaches. Use one or the other.
Which Means ? Please Advice . I’m Stucked with the code…
Ok
start new Gadgeteer project and don’t modify Program.Generated.cs at all.
Add your modules and connect them in the designer
Move HC_SR04 class into its own cs file.
ProgramStarted method should be in Program.cs now.
declare a class variable for HC_SR04 inside Program.cs
Instantiate it in ProgramStarted
Create Timer and take measurements inside Timer Tick handler.
Hi Architect ,
I have modified the code as you said but the out is the same …
using Gadgeteer.Interfaces;
using HC_SR04;
namespace archi
HC_SR04.HC_SR04 sensor;
timer.Start();
sensor = new HC_SR04.HC_SR04(EMX.Pin.IO8, EMX.Pin.IO45);
Thread.Sleep(100);
if (ticks > 0L)
The first thing I would try to determine is if an interrupt is occurring. if not, there is a wiring issue.
If the interrupt is occurring, I would print out the timing values and make sure the numbers make sense.
There is a value for overhead. Is this number appropriate for the MF device you are using? If this
number is too big, it could make the ping results go bad. Try setting to zero. First get it working
and then calibrate.
Don’t do while(true) loop inside the Timer handler. And make it class variable. Something like this:
timer.Start();
if (ticks > 0L)
Debug.Print(inches.ToString());
Thanks Architect You are Awesome
You are welcome!
To be more safe in case pin out changes or you move it to a different socket I would use something like this when creating the sensor:
Socket socket = Socket.GetSocket(10, true, null, null);
sensor = new HC_SR04(socket.CpuPins[5], socket.CpuPins[3]);
