hey guys need help …
help me to change this code to work on FEZ SPIDER… here is the code, this code for HC SR04 ultrasonic sensor
using SecretLabs.NETMF.Hardware;
using SecretLabs.NETMF.Hardware.Netduino;
namespace HC_SR04
/// <summary>
/// Class for controlling the HC-SR04 Ultrasonic Range detector
/// Written by John E. Wilson
/// Version 1.1 - 2012/04/03 - Corrected constructor pin documentation
/// Free to use, please attribute credit
/// </summary>
public class HC_SR04
private OutputPort portOut;
private InterruptPort interIn;
private long beginTick;
private long endTick;
private long minTicks; // System latency, subtracted off ticks to find actual sound travel time
private double inchConversion;
private double version;
/// <summary>
/// Constructor
/// </summary>
/// <param name="pinTrig">Netduino pin connected to the HC-SR04 Trig pin</param>
/// <param name="pinEcho">Netduino pin connected to the HC-SR04 Echo pin</param>
public HC_SR04(Cpu.Pin pinTrig, Cpu.Pin pinEcho)
portOut = new OutputPort(pinTrig, false);
interIn = new InterruptPort(pinEcho, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeLow);
interIn.OnInterrupt += new NativeEventHandler(interIn_OnInterrupt);
minTicks = 6200L;
inchConversion = 1440.0;
version = 1.1;
/// <summary>
/// Returns the library version number
/// </summary>
public double Version
get
return version;
/// <summary>
/// Trigger a sensor reading
/// Convert ticks to distance using TicksToInches below
/// </summary>
/// <returns>Number of ticks it takes to get back sonic pulse</returns>
public long Ping()
// Reset Sensor
portOut.Write(true);
Thread.Sleep(1);
// Start Clock
endTick = 0L;
beginTick = System.DateTime.Now.Ticks;
// Trigger Sonic Pulse
portOut.Write(false);
// Wait 1/20 second (this could be set as a variable instead of constant)
Thread.Sleep(50);
if (endTick > 0L)
// Calculate Difference
long elapsed = endTick - beginTick;
// Subtract out fixed overhead (interrupt lag, etc.)
elapsed -= minTicks;
if (elapsed < 0L)
elapsed = 0L;
// Return elapsed ticks
return elapsed;
// Sonic pulse wasn't detected within 1/20 second
return -1L;
/// <summary>
/// This interrupt will trigger when detector receives back reflected sonic pulse
/// </summary>
/// <param name="data1">Not used</param>
/// <param name="data2">Not used</param>
/// <param name="time">Transfer to endTick to calculated sound pulse travel time</param>
void interIn_OnInterrupt(uint data1, uint data2, DateTime time)
// Save the ticks when pulse was received back
endTick = time.Ticks;
/// <summary>
/// Convert ticks to inches
/// </summary>
/// <param name="ticks"></param>
/// <returns></returns>
public double TicksToInches(long ticks)
return (double)ticks / inchConversion;
/// <summary>
/// The ticks to inches conversion factor
/// </summary>
public double InchCoversionFactor
get
return inchConversion;
set
inchConversion = value;
/// <summary>
/// The system latency (minimum number of ticks)
/// This number will be subtracted off to find actual sound travel time
/// </summary>
public long LatencyTicks
get
return minTicks;
set
minTicks = value;
HC_SR04 sensor = new HC_SR04(Pins.GPIO_PIN_D6, Pins.GPIO_PIN_D7);
long ticks = sensor.Ping();
if (ticks > 0L)
double inches = sensor.TicksToInches(ticks);
there are several examples and threads on this sensor. If you can’t re-factor the code for Spider, just go back to one of those working samples.
Secretlabs is the netduino equivalent of GHI.premium. If they use functions specifically built on their hardware, you will not simply be able to transfer over to spider (same as the other way if you use premium library functions)
ok, architect i just do what you said i remove those secret labs…for the extender what are the reference i nee to add how to write the new code for those pin?
You will need to get Socket first providing the number of the socket you have connected the extender to. The you can get any pin from the socket object and use it to pass to the sensor driver constructor.
[b]HC_SR04 sensor = new HC_SR04(Pins.GPIO_PIN_D6, Pins.GPIO_PIN_D7);[/b]
if (ticks > 0L)
in the above code i have an error with the bold line “pins” it says “the word pins does not exist in the current context” how to fix this? this code is related with previous code i post here
no architect this is the whole code of the project i’m face with problem i mention above
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using Gadgeteer;
//using SecretLabs.NETMF.Hardware;
//using SecretLabs.NETMF.Hardware.Netduino;
namespace HC
private Socket _socket;
/// <summary>
/// Constructor
/// </summary>
minTicks = 6200L;
version = 1.1;
/// <summary>
/// </summary>
get
return version;
/// <summary>
/// </summary>
public long Ping()
// Reset Sensor
Thread.Sleep(1);
// Start Clock
endTick = 0L;
Thread.Sleep(50);
if (endTick > 0L)
if (elapsed < 0L)
elapsed = 0L;
return elapsed;
return -1L;
/// <summary>
/// </summary>
/// <summary>
/// </summary>
/// <summary>
/// </summary>
get
set
/// <summary>
/// </summary>
get
return minTicks;
set
minTicks = value;
if (ticks > 0L)
Because those are the pins that were used in that example on netduino. You have to provide pins you are using on the spider using Spider pin enumeration. What socket and pins are you connecting it to?
using Gadgeteer;
using GHI.Premium.Hardware;
namespace HC
Socket _socket;
/// <summary>
/// Constructor
/// </summary>
// public HC_SR04(EMX.Pin pinTrig, EMX.Pin pinEcho)
minTicks = 6200L;
version = 1.1;
/// <summary>
/// </summary>
get
return version;
/// <summary>
/// </summary>
public long Ping()
// Reset Sensor
Thread.Sleep(1);
// Start Clock
endTick = 0L;
Thread.Sleep(50);
if (endTick > 0L)
if (elapsed < 0L)
elapsed = 0L;
return elapsed;
return -1L;
/// <summary>
/// </summary>
/// <summary>
/// </summary>
/// <summary>
/// </summary>
get
set
/// <summary>
/// </summary>
get
return minTicks;
set
minTicks = value;
//HC_SR04 sensor = new HC_SR04(Pins.GPIO_PIN_D6, Pins.GPIO_PIN_D7);
HC_SR04 sensor = new HC_SR04(EMX.Pin.IO45, EMX.Pin.IO8);
if (ticks > 0L)
