Call me on it if I’m wrong but, to me that looks like the sample code with the networking code for an ethernet module included.
I don’t have a problem with my ethernet module, I can connect to the network and internet fine with it. Never the less, I went along and took the sample code and added code for the ethernet module.
I’ve tried it with the verison in the GHI.Premium libraries and the one in Gadgeteer.Modules.GHIElectronics.Ethernet_JD11
Both times I come out with the same result which is the following exception:
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (1) ####
#### Message:
#### Microsoft.SPOT.Net.Security.SslNative::SecureConnect [IP: 0000] ####
#### Microsoft.SPOT.Net.Security.SslStream::Authenticate [IP: 0060] ####
#### Microsoft.SPOT.Net.Security.SslStream::AuthenticateAsClient [IP: 000c] ####
#### System.Net.HttpWebRequest::EstablishConnection [IP: 023d] ####
#### System.Net.HttpWebRequest::SubmitRequest [IP: 0019] ####
#### System.Net.HttpWebRequest::GetResponse [IP: 000c] ####
#### GadgeteerApp1.Program::ProgramStarted [IP: 0089] ####
#### GadgeteerApp1.Program::Main [IP: 0015] ####
#### SocketException ErrorCode = 1
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.Security.dll
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in System.Net.Security.dll
#### Exception System.Net.WebException - 0x00000000 (1) ####
#### Message:
#### System.Net.HttpWebRequest::GetResponse [IP: 00c8] ####
A first chance exception of type ‘System.Net.WebException’ occurred in System.Http.dll
Exception in HttpWebRequest.GetResponse(): System.Net.WebException
The code looks
using System.IO;
using System.Net;
using System.Text;
using Microsoft.SPOT.Net.Security;
using System.Security.Cryptography.X509Certificates;
using GHI.Premium.Net;
using System.Collections;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace HttpClientSample
public class MyHttpClient
/// <summary>
/// Retrieves a page from a Web server, using a simple GET request.
/// </summary>
EthernetBuiltIn ethernet = new EthernetBuiltIn();
ethernet.Open();
ethernet.NetworkInterface.EnableDhcp();
ethernet.NetworkInterface.EnableDynamicDns();
NetworkInterfaceExtension.AssignNetworkingStackTo(ethernet);
Microsoft.SPOT.Hardware.Utility.SetLocalTime(new DateTime(2013, 11, 14));
// Wait for DHCP (on LWIP devices)
IPAddress ip = IPAddress.GetDefaultLocalAddress();
if (ip != IPAddress.Any) break;
Thread.Sleep(1000);
// Root CA Certificate needed to validate HTTPS servers.
byte[] ca = Resource1.GetBytes(
Resource1.BinaryResources.VerisignCA);
X509Certificate[] caCerts =
new X509Certificate[] { new X509Certificate(ca) };
// Initialize the default webproxy to be used by all
// HttpWebRequests.
// Change the proxy address to fit your environment.
HttpWebRequest.DefaultWebProxy = null;
// Print the HTTP data from each of the following pages.
PrintHttpData("http://autos.msn.com/default.aspx", null);
PrintHttpData("http://www.nytimes.com/", null);
PrintHttpData("https://www.google.com/accounts/ManageAccount/", null);
// Read from secure webpages by using the Verisign Root CA
// certificate that is stored in the Resource1.resx file.
//This crashes with the above exception
caCerts);
/// <summary>
/// Prints the HTTP Web page from the given URL and status data while
/// receiving the page.
/// </summary>
/// <param name="url">The URL of the page to print.</param>
/// <param name="caCerts">The root CA certificates that are required for
/// validating a secure website (HTTPS).</param>
public static void PrintHttpData(string url, X509Certificate[] caCerts)
// Create an HTTP Web request.
HttpWebRequest request =
HttpWebRequest.Create(url) as HttpWebRequest;
// Assign the certificates. The value must not be null if the
// connection is HTTPS.
request.HttpsAuthentCerts = caCerts;
// Set request.KeepAlive to use a persistent connection.
request.KeepAlive = true;
// Get a response from the server.
WebResponse resp = null;
try
resp = request.GetResponse(); //This is where the exception is caused
catch (Exception e)
Debug.Print("Exception in HttpWebRequest.GetResponse(): " +
e.ToString());
// Get the network response stream to read the page data.
if (resp != null)
Stream respStream = resp.GetResponseStream();
string page = null;
byte[] byteData = new byte[4096];
char[] charData = new char[4096];
int bytesRead = 0;
Decoder UTF8decoder = System.Text.Encoding.UTF8.GetDecoder();
int totalBytes = 0;
// allow 5 seconds for reading the stream
respStream.ReadTimeout = 5000;
// If we know the content length, read exactly that amount of
// data; otherwise, read until there is nothing left to read.
if (resp.ContentLength != -1)
for (int dataRem = (int)resp.ContentLength; dataRem > 0; )
Thread.Sleep(500);
bytesRead =
respStream.Read(byteData, 0, byteData.Length);
if (bytesRead == 0)
Debug.Print("Error: Received " +
(resp.ContentLength - dataRem) + " Out of " +
resp.ContentLength);
break;
dataRem -= bytesRead;
// Convert from bytes to chars, and add to the page
// string.
int byteUsed, charUsed;
bool completed = false;
totalBytes += bytesRead;
UTF8decoder.Convert(byteData, 0, bytesRead, charData, 0,
bytesRead, true, out byteUsed, out charUsed,
out completed);
page = page + new String(charData, 0, charUsed);
// Display the page download status.
Debug.Print("Bytes Read Now: " + bytesRead +
" Total: " + totalBytes);
page = new String(
System.Text.Encoding.UTF8.GetChars(byteData));
// Read until the end of the data is reached.
// If the Read method times out, it throws an exception,
// which is expected for Keep-Alive streams because the
// connection isn't terminated.
try
Thread.Sleep(500);
bytesRead =
catch (Exception)
bytesRead = 0;
// Zero bytes indicates the connection has been closed
// by the server.
if (bytesRead == 0)
break;
out completed);
// Display page download status.
Debug.Print("Total bytes downloaded in message body : "
+ totalBytes);
// Display the page results.
Debug.Print(page);
// Close the response stream. For Keep-Alive streams, the
// stream will remain open and will be pushed into the unused
// stream list.
resp.Close();
I’ve been stuck at this point so long now I feel it may be a hardware error, as I said before it runs fine on the emulator (as long as you don’t include the GHI.Premium part).
