Hello
I want to handle my display views using wpf. but after this line of code executed :
I get this error :
[quote]ERROR: You can only use WPF on one display (and if an LCD is present, only on the LCD)[/quote]
I've connect my n18 display to raptor mainboard on socket 11...
what is the problem?!
The message says thet the LCD Controller is enabled and I guess WPF is bound to it by Default.
What Kind of Project do you have Gadgeteer or plain NETMF?
Check if a Display is configured for your raptor with FEZ Config.
Please post all your initialization code up to the line that Fails.
Do you have, or have you had, a LCD display, like the TE35, attached to your mainboard? If so, reload the firmware. This will disassociate the LCD display from the board.
