My FEZ Panda is in bootloader mode and now i cant access to the panda says:( usb not recognised)
need your help i was tasting about bootloader so i wroted some code and after this i cant access to the device, what is solution for this problem?
here is code:
  SystemUpdate.AccessBootloader();
            if (SystemUpdate.GetMode() != SystemUpdate.SystemUpdateMode.Bootloader)
                throw new InvalidOperationException("We must be in bootloader mode!");
            PersistentStorage sd = new PersistentStorage("SD");
            sd.MountFileSystem();
            string fileName = "\\SD\\app.hex";
            FileStream file = new FileStream(fileName, FileMode.Open, FileAccess.Read);
            // start update
            SystemUpdate.ApplicationUpdate.Start();
            // read the file in chucks
            byte[] buffer = new byte[10 * 1024];
            int length;
            do
                length = file.Read(buffer, 0, buffer.Length);
                SystemUpdate.ApplicationUpdate.Write(buffer, 0, length);
            } while (length == buffer.Length);
            file.Close();
            // End update
            SystemUpdate.ApplicationUpdate.End();
            // Access the application
            SystemUpdate.AccessApplication();
Force in GHI loader (loader button) and erase all device, using E
