i have gsm modem by this i want to connect windows service, and download new application version file, and save it into SD, after download i want to update my application from SD, so how to do this can someone help me.
FEZ Panda II.
For gsm:
http://code.tinyclr.com/project/278/gsm-driver/
For the rest of it:
take a look at Pyxis2 code it has everything you need.
thanks but i dont need gsm modem driver,
an one question how i can get my app hex file?
Read documentation:
Hint: Paragraph title is “Obtaining the Application File”
need your help please :((
here is my code which don’t works
here comes exeption:
" SystemUpdate.ApplicationUpdate.Start(); "
#region Class Level Variables
private static Program mInstance;
private static InterruptPort mUpdateBTN;
private static PersistentStorage mSDStorage;
private static bool Installing = false;
#endregion
#region Event Handlers
private static void OnInterrupt(uint data1, uint data2, DateTime time)
if (PersistentStorage.DetectSDCard())
mInstance.StartUpdate();
#endregion
#region Methods
mInstance = new Program();
mInstance.GetMode();
if (SystemUpdate.GetMode() != SystemUpdate.SystemUpdateMode.Application)
throw new InvalidOperationException("We are not in application mode!");
mSDStorage = new PersistentStorage("SD");
mSDStorage.MountFileSystem();
mUpdateBTN = new InterruptPort((Cpu.Pin)FEZ_Pin.Digital.LDR, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
mUpdateBTN.OnInterrupt += OnInterrupt;
Debug.Print("This is the normal application working...");
private void StartUpdate()
var mFileName = GetRootDirectory() + "\\app.hex";
Debug.Print("Going To Read Data");
InstallUpdate(mFileName);
private string GetRootDirectory()
var volumes = VolumeInfo.GetVolumes();
if (volumes.Length > 0)
return volumes[0].RootDirectory;
return "";
private void GetMode()
var mode = SystemUpdate.GetMode();
Debug.Print("Current Mode Is: " + mode);
switch (mode)
case SystemUpdate.SystemUpdateMode.NonFormatted:
SystemUpdate.EnableBootloader();
break;
case SystemUpdate.SystemUpdateMode.Bootloader:
throw new Exception("Invalid Boot Mode!");
private void InstallUpdate(string sPath)
bool bComplete = true;
Installing = true;
// start update
if (!InstallFile(sPath))
Debug.Print("FAILED");
bComplete = false;
return;
try
File.Delete(sPath);
catch
//ignore
if (bComplete)
SystemUpdate.ApplicationUpdate.End();
SystemUpdate.AccessApplication();
private bool InstallFile(string sFile)
try
FileStream file = new FileStream(sFile, FileMode.Open, FileAccess.Read);
byte[] buffer = new byte[10 * 1024];
int length;
do
length = file.Read(buffer, 0, buffer.Length);
SystemUpdate.ApplicationUpdate.Write(buffer, 0, length);
} while (length == buffer.Length);
file.Close();
return true;
catch
return false;
I don’t see where you call AccessBootloader. Follow the instructions in the documentation. Have you looked at Pyxis2 code?
i had AccessBootloader but it gives me exeption and then removed it
only what i need is to update my program from sd, and someone has some small source code.
i have Fez Panda II.
yes i looked at pyxis code but there i could not find there also accessbootloader.
this is my new source code but still nothing
private void EnsureLogFile(string path)
if (!File.Exists(path))
File.Create(path).Dispose();
private void LogToFile(string input)
var filename = GetRootDirectory() + "\\" + DateTime.Now.ToString("ddMMyyyy") + ".log";
EnsureLogFile(filename);
using (var fs = new FileStream(filename, FileMode.Append, FileAccess.Write))
var sw = new StreamWriter(fs);
Debug.Print("writing: " + input);
sw.WriteLine(input);
sw.Close();
fs.Close();
private string GetFirmwarePath()
var fileName = GetRootDirectory();
if (fileName != null)
fileName += "\\" + "app.hex";
if (File.Exists(fileName))
return fileName;
return null;
SystemUpdate.SystemUpdateMode mode = SystemUpdate.GetMode();
mInstance.LogToFile("EMX starts. Mode: " + mode.ToString());
// Allow firmware on the board to be upgradable.
if (mode == SystemUpdate.SystemUpdateMode.NonFormatted)
// Force a hard reboot
PowerState.RebootDevice(false);
// Start to upgrade firmware
if (mode == SystemUpdate.SystemUpdateMode.Bootloader)
mInstance.LogToFile("Start to upgrade ...");
// Force mount all removable disks...
var firmwarePath = mInstance.GetFirmwarePath();
if (firmwarePath != null)
// Start to upgrade
try
using (FileStream fs = new FileStream(firmwarePath, FileMode.Open, FileAccess.Read))
int len = 0;
do
len = fs.Read(buffer, 0, buffer.Length);
SystemUpdate.ApplicationUpdate.Write(buffer, 0, len);
} while (len == buffer.Length);
catch (Exception ex)
mInstance.LogToFile("Failed to upgrade.");
//Restart
if (mode == SystemUpdate.SystemUpdateMode.Application)
if (File.Exists(mInstance.GetFirmwarePath()))
mInstance.LogToFile("Prepare to upgrade. Rebooting ...");
SystemUpdate.AccessBootloader();
Thread.Sleep(5000);
To find what you need in Pyxis 2:
Enabling/Accessing: /Progam.cs
Updating from SD: Pyxis2Updater/Program.cs
