The original was right. Your modifications broke it,but don’t worry. Try this:
namespace Sensor
public class TMP102
I2CDevice.Configuration _TMP102 = null;
I2CDevice _i2c = null;
public enum ADD0
Gnd,
Vcc,
SDA,
SCL
public enum ConversionRate
quarter_Hz,
one_Hz,
four_Hz,
eight_Hz
public enum ThermostatMode
ComparatorMode,
InterruptMode
public enum AlertPolarity
activeLow,
activeHigh
public enum ConsecutiveFaults
one,
two,
four,
six
private enum Registers
Temperature = 0x00,
Configuration = 0x01,
T_low = 0x02,
T_high = 0x03
private ushort _sensorAddress;
private byte[] _registerNum = new byte[1] { (byte)Registers.Configuration };
private byte[] _registerValue = new byte[2];
private float _temperature = 0.0f;
private bool _oneShotMode;
private AlertPolarity _alertPolarity;
private ThermostatMode _thermostatMode;
private ConsecutiveFaults _consecutiveFaults;
public bool Init(ADD0 addressSelect)
return Init(addressSelect, false, AlertPolarity.activeHigh, ConversionRate.four_Hz, ThermostatMode.ComparatorMode, ConsecutiveFaults.one, 0, 0);
public bool Init(
ADD0 addressSelect = ADD0.Gnd,
bool oneShotMode = false,
AlertPolarity alertPolarity = AlertPolarity.activeHigh,
ConversionRate conversionRate = ConversionRate.four_Hz,
ThermostatMode thermostatMode = ThermostatMode.ComparatorMode)
return Init(addressSelect, oneShotMode, alertPolarity, conversionRate, thermostatMode, ConsecutiveFaults.one, 0, 0);
private bool Init(
ADD0 addressSelect,
bool oneShotMode,
AlertPolarity alertPolarity,
ConversionRate conversionRate,
ThermostatMode thermostatMode,
ConsecutiveFaults consecutiveFaults,
ushort limitHigh,
ushort limitLow)
// Sleep past first conversion
Thread.Sleep(30);
switch (addressSelect)
case ADD0.Gnd: _sensorAddress = 0x90 >> 1; break;
case ADD0.Vcc: _sensorAddress = 0x92 >> 1; break;
case ADD0.SDA: _sensorAddress = 0x94 >> 1; break;
case ADD0.SCL: _sensorAddress = 0x96 >> 1; break;
// this is the I2C bus definitiion? (combined with object?)
//_TMP102=new I2CDevice(new I2CDevice .Configuration(_sensorAddress, 100));
// Splitting this up..
// object
_TMP102 = new I2CDevice.Configuration(_sensorAddress, 100);
// bus
_i2c = new I2CDevice(_TMP102);
_alertPolarity = alertPolarity;
_oneShotMode = oneShotMode;
_thermostatMode = thermostatMode;
_consecutiveFaults = consecutiveFaults;
_registerNum[0] = (byte)Registers.Configuration;
int bytesTransfered = ReadRegister();
if (bytesTransfered == 3)
if (_oneShotMode)
_registerValue[0] = (byte)(_registerValue[0] | 0x01);
_registerValue[0] = (byte)(_registerValue[0] & 0xfe);
if (_thermostatMode == ThermostatMode.InterruptMode)
_registerValue[0] = (byte)(_registerValue[0] | 0x02);
_registerValue[0] = (byte)(_registerValue[0] & 0xfd);
if (_alertPolarity == AlertPolarity.activeLow)
_registerValue[0] = (byte)(_registerValue[0] | 0x04);
_registerValue[0] = (byte)(_registerValue[0] & ~0x04);
switch (conversionRate)
case ConversionRate.quarter_Hz: _registerValue[1] = (byte)((_registerValue[1] & 0x3f) | (0x00 << 6)); break;
case ConversionRate.one_Hz: _registerValue[1] = (byte)((_registerValue[1] & 0x3f) | (0x01 << 6)); break;
case ConversionRate.four_Hz: _registerValue[1] = (byte)((_registerValue[1] & 0x3f) | (0x02 << 6)); break;
case ConversionRate.eight_Hz: _registerValue[1] = (byte)((_registerValue[1] & 0x3f) | (0x03 << 6)); break;
bytesTransfered = WriteRegister();
Thread.Sleep(30);
return (bytesTransfered == 3);
public float Read()
int bytesTransfered;
if (_oneShotMode)
ReadRegister();
if ((_registerValue[0] & 0x01) == 0x01)
// Toggle OS bit
_registerValue[0] |= 0x80;
WriteRegister();
// Sleep so conversion can start
Thread.Sleep(1);
// Wait for OS bit to toggle back to 1
do
ReadRegister();
while ((_registerValue[0] & 0x80) == 0x00);
_registerNum[0] = (byte)Registers.Temperature;
int temp = ((_registerValue[0] << 4) | (_registerValue[1] >> 4));
if ((temp & 0x0800) == 0x0800)
_temperature -= 1;
_temperature = ~temp;
_temperature = temp & 0x0FFF;
_temperature = (float)temp * -0.0625f;
_temperature = (float)temp * 0.0625f;
return _temperature;
public float asCelcius()
public float asFahrenheit()
return (asCelcius() * 9.0f / 5.0f) + 32.0f;
public float asKelvin()
return (asCelcius() + 273.15f);
public float asRankine()
return (asKelvin() * 9.0f / 5.0f);
private int ReadRegister()
I2CDevice.I2CTransaction[] xActions = new I2CDevice.I2CTransaction[2];
xActions[0] = I2CDevice.CreateWriteTransaction(_registerNum);
xActions[1] = I2CDevice.CreateReadTransaction(_registerValue);
return _i2c.Execute(xActions, 30); // << This line gives the error type 'System.NullReferenceException'
private int WriteRegister()
I2CDevice.I2CTransaction[] xActions = new I2CDevice.I2CTransaction[1];
xActions[0] = I2CDevice.CreateWriteTransaction(new byte[] { _registerNum[0], _registerValue[0], _registerValue[1] });
