I’m trying to build my first Cobra II app w/ SDK4.2. Up to now, it’s been 4.1 Panda II apps. I’ve installed 4.2 and updated the loader and firmware on my Cobra II that’s been sitting on the shelf. Pinging works.
When I fire up VS 2010 these two Cobra app templates are listed:
FEZ Cobra Console Application
FEZ Cobra Windows Application
Selecting Console App, I switch from Emulator to USB and the Cobra is found.
However, when I build the console app it uses SDK 4.1. When I specify 4.2 as the target framework (under Properties) I need to exit VS and restart for jt to build with 4.2 properly. So question #1 is, how do I get VS to use 4.2 for a Cobra app initially and avoid restarting VS?
Further, when I attempt to run the console app template, which includes
(the template blinks the onboard LED) I cannot find the appropriate assembly. That file is not on my computer. Assemblies in 4.2 seem to start with GHI. and not GHIElectronics… There is also a Premium library and a OSHW library.
Am I using an old template? Do I need to set something in VS to default to 4.2?
