Hello guys, since I’m having issues with the new firmware (See here ) http://www.tinyclr.com/forum/topic?id=8560
i was wondering if anyone knows WHERE To get the previous version of the firmware? the non QEF2 version…
i looked all over the resource page on the Mountaineer Site and couldn’t find it… tried to use the contact us page to ask the question and i was directed here so it sounds like GHI is owning the support on this board… at least i know i won’t be lost for long
On http://www.mountaineer.org/resources/ see the section “SDK and drivers”, the original QFE1 firmware is still there, and at the moment I’d recommend to stay with it until we have done some more tests:
To go back to the previous version, do the following:
Connect the board and open MFDeploy, select “USB”
Even if ping doesn’t work, press “SW” on the board and keep it pressed, press and release “Reset” and finally release "SW. The device must be now in bootloader mode. When pinging, you should get: “TinyBooter Bootloader build info: Copyright Oberon microsystems, Inc.”
Click “Erase” and select “Firmware and Deployment”, Erase
Click “Browse” and select both “ER_CONFIG.hex” and “ER_FLASH.hex”
That’s the problem it doesn’t work…
MFDeploy can’t ping or erase the board even in bootloader mode … the only way i can access the board is through the STDFU tool…
Note that when i load the Cerberus tinyloader using the STDF tool the board becomes responsive through MFDeploy… i hope this helps narrow down the issue…
Any other suggestions!!!
thanks.
when i say i can access it through STDFU tool, that’s not at the same time as MFDeploy, i know MFDeploy doesn’t see the Boards in DFU mode… and that STDFU doesn’t see the boards in Bootloader mode
SO in short: if i start the Device Normal: MFDEPLOY sees the board but can’t ping…
If i start the Board in Boot-loader mode: Using the SW and Reset button… MFDeploy sees the board but can’t ping.
when those two fail i resort to the STDFU tool:
i plug the extender to Socket 8, jump pin 1 and 8. reset the board now I’m in DFU mode and i can see it in STDFU Protocol and i can re flash the firmware… 42QEF2 since that is the only one that comes in DFU package… so i’m STUCK with this one since i can’t deploy 42QEF1…
when that’s done i repeat the above steps and the same thing happens…
So what do i need :
i need a DFU package for QEF1 to try using the STDFU tool… since that’s the only way i can flash firmware…
