hi,
I’m a newbie on electronics starting a proyect, an aquarium control device. Looking at the lighting control part of the proyect, i’ll have several leds divided on 4 channel and the driver for the leds need PWM signal, so i will need 4 pwm pins combined with other stuff i want to do i maybe short of PWM.
So i can use this
If not, what you guys recomend?
in case the led driver is the Mean Well ELN-60-48P, here
http://www.meanwell.com/search/eln-60/default.htm
and the specs here
http://www.rapidled.com/servlet/the-26/Mean-Well-ELN-dsh-60-dsh-48P-dimmable/Detail
