@ scardinale - Cool Job
Does this work on the 429-DISCO too ?
And if so, where can the driver be downloaded from ?
Not yet, the F429 Disco uses a different IC. But I am working on that as well.
Once I finish the driver, I will post it in codeshare.
@ scardinale - Merci bien, mon ami !!
After near one month of work, here are some news about native display support.
You may already know that we could use multiple different displays at the same time :
But it was not enough, so now you can use up to four identical displays at the same time on our boards !
Here is an example with a Quail and four ILI9341 (240x320), all displaying something different (although very similar, I admit ) on the whole screen surface :
As you may have noticed, each display can be rotated independently as well.
Another example with a Dalmatian board and two ILI9163 (128x128) :
And finally, letโs have some fun with a Tuatara and again the ILI9163 displays :
For information, just before the demos start, we have 166KB free memory, so there is still enough for complex programs.
