I have ordered the board, so I will be able to do some tests in the next few weeks. I will tell you how it is going.
For those who might be interested, we now have a web site : http://www.mikrobusnet.org
It contains source code, tutos and templates to start using Click boards with NETMF. If you have Click boards, you can even help by coding drivers (there are templates for this).
@ Bec a Fuel - Congratulations! This is a great product. Looking forward to more great boards to come.
P.S. Couldnāt register on your forumā¦ I canāt seem to get past the captcha input, the error message is in French!
@ Bec a Fuel - I have some click board ADC, DAC and eth ā¦ I must check
Thank you for your support ! But donāt forget that Iām not the only one involved in this project
ADC and DAC drivers are already doneā¦ Too late
http://www.mikrobusnet.org/#!netmf-drivers/component_71401
@ Bec a Fuel - are there modules you want built for this? Waiting for OSH 2 weeks at a time (especially when you made mistake) means time for research and other designs.
I understand this is build on an existing system with modules on place already.
@ mhectorgato : I hope I understand correctly what you sayā¦
What I understand is that you are proposing to built Click boards, arenāt you ? If so, then any module not already present in the (huge) list of MikroElektronika is welcome, of course. ( Click Boards - MIKROE )
Quite the selection!
While waiting for your module ( ), Iāve added two more drivers : DCMotor and Thunder.
You can see them in action on http://www.mikrobusnet.org . Source code is available on the NETMF drivers page.
I also wish to thank the users that have joined us to help coding drivers It is very motivating for us !
Hello,
2 new drivers have been added : DCMotor and nRF-C :
The DC motor used here has a 231:1 gearbox, hence the relatively small speed, even at 100% PWM
In this video, the Dalmatian board (white PCB) is sending the text āIteration Nā with N increasing by 1 every 2 seconds.
The Quail board is acting as the receiver and is only displaying the received text.
Code for the receiver is quite simple :
using System.Text;
using MikroBusNet;
namespace Examples
public partial class Program
public static void StartReceiver()
nrf.Configure(Encoding.UTF8.GetBytes("RCVR"), 1, NRFC.DataRate.DR250kbps);
nrf.OnDataReceived += nrf_OnDataReceived;
nrf.Enable();
private static void nrf_OnDataReceived(byte[] data)
Debug.Print("Received : "+ new string(Encoding.UTF8.GetChars(data)));
For the nRF-C driver, I would like to say a BIG thank you to [em]Gralin[/em] for his driver (available on Codeplex : http://nrf24l01.codeplex.com/ )
It only needed a few cosmetic changes to conform to our driversā scheme and it worked like a charm on the first try !
As usual, source codes are available on the site : http://www.mikrobusnet.org
Hello,
we now have some help from other persons and are proud to show a new bunch of drivers :
- SHT11
- Digipot
- Buzzer
- 4x20 LCD & Keypad 4x3 (non-Click boards)
Thank you
You can find more info and driversā code on our site : http://www.mikrobusnet.org
Christophe
Lubbly Jubbly
Hello,
thanks to our active members, here are 4 new drivers available :
- Accel Click board
- Altitude Click board
- Parallax Serial Lcd
- DS18B20 1-Wire sensor
As a reminder, you can see demo videos and get any source code on http://www.mikrobusnet.org
Thank you to those guys who are making a very good work
Hello,
in the past 22 days, and thanks to a prolific user, new Click boards drivers have been added in our growing list :
- Light
- Thermo
- RTC
- RTC2
- Current
- USB-UART
For those who do not follow us but still want to see boards/drivers in action, you can find everything you want on the MBN website : http://mikrobusnet.org
Christophe
Insanely awsome!
Congratulations guys!
