I am going to buy a FEZ Rhino for evaluation purposes. I recently developed a Domino application and I would like to know if there are any known issue migrating from Domino to Rhino. Now my application uses these Domino features:
USB client (now I am deploying software using an FTDI cable and the RS232);
Ethernet shield;
External graphic display.
So the FEZ Rhino OEM Kit seems to be the right choice for my project.
Do you think I could have problems migrating?
Looking at the Rhino board pics I was not able to see if there is a switch to configure the Rhino for deploying software via RS232. Do you know if this is possible?
finally it arrived!!!
A beautiful Rhino OEM kit with ethernet soldered! Beafutiful! I’m going to test it. Is it correct to connect the pin 36 to 3.3 volt to use the usb client feature?
Thank you very much for your help!
BTW: only 5 days to deliver the Rhino directly from GHI to Italy!!! Great!
