Micropython on the brainpad
Hi everyone,
I have a brainpad and i tried to flash it with micropython based on the instructions on the installing micropython on the brainpad. I flashed the device but when i plug it it does not create a virtual serial interface or COM port on my machine.
Has anyone been able to install micropython ? which version did you use and are you able to communicate with it using REPL ?
Cheers
@Bauland done some experimenting with micropython and created firmware for brainpad2 too.
Thank you again for your quick responses. I appreciate this community so much . Where you can post and get help from amazing people .
Firmware can be found here: firmware
Firmware is provided with no warranties ! :grinning:
thanx a lot
thank you so much :slight_smile: i will give this a try tonight. Really appreciate it.
THANK YOU! SO MUCH
this actually worked i uploaded the firmware into my brain pad and it was detected. This is amazing.
You made my week :slight_smile:
Cheers
@Bauland , @mmaldonado
tested with Thonny IDE 3.2.7 and Thonny IDE 3.3.0b2 and work pretty well
this is awesome :slight_smile: , yeah i tested this using Mobaterm using python via the terminal and also by creating a file inside the created drive :slight_smile: thinks worked . very excited about the posibilities.
