Micro sd used in fez spider
An unhandled exception of type ‘System.InvalidOperationException’ occurred in GHIElectronics.NETMF.IO.dll. this error shown how to solve.
            their name followed by a period, e.g.  button.  or  camera.
                timer.Tick +=<tab><tab>
                timer.Start();
            sdPS = new PersistentStorage("SD");
            // Mount the file system
            sdPS.MountFileSystem();
            // Assume one storage device is available, access it through
            // Micro Framework and display available files and folders:
            Debug.Print("Getting files and folders:");
            if (VolumeInfo.GetVolumes()[0].IsFormatted)
                string rootDirectory =
                    VolumeInfo.GetVolumes()[0].RootDirectory;
                string[] files = Directory.GetFiles(rootDirectory);
                string[] folders = Directory.GetDirectories(rootDirectory);
                Debug.Print("Files available on " + rootDirectory + ":");
                for (int i = 0; i < files.Length; i++)
                    Debug.Print(files[i]);
                Debug.Print("Folders available on " + rootDirectory + ":");
                for (int i = 0; i < folders.Length; i++)
                    Debug.Print(folders[i]);
                Debug.Print("Storage is not formatted. Format on PC with FAT32/FAT16 first.");
this is my code plz help me
nevermind…
@ Justin -
using System.IO;
using Microsoft.SPOT.IO;
//using Gadgeteer.Modules.GHIElectronics;
namespace SD_card
    public partial class Program
        PersistentStorage sdPS;
                timer.Start();
this is my full code
Have a look here http://www.tinyclr.com/codeshare/entry/338
this question belongs in the Gadgeteer forum. you will be told what your problem is there.
Hi there,
Since you are using the Spider…which is a Gadgeteer Compatible board all you’d have to do is this:
    sdCard.SDCardMounted += new SDCard.SDCardMountedEventHandler(sdCard_SDCardMounted);
    sdCard.SDCardUnmounted += new SDCard.SDCardUnmountedEventHandler(sdCard_SDCardUnmounted);
void sdCard_SDCardUnmounted(SDCard sender)
    Debug.Print("The SD card has been unmounted");
    Debug.Print("DO NOT try to access it without mounting it again first");
void sdCard_SDCardMounted(SDCard sender, GT.StorageDevice SDCard)
    Debug.Print("SD card has been successfully mounted. You can now read/write/create/delete files");
    Debug.Print("Unmount before removing");
I would also recommend you go through the Gadgeteer tutorials here:
and this is for the SDCard:
and Codeshare has many examples as well.
http://www.tinyclr.com/codeshare/search?q=sd+card
Enjoy!
