Can I get the part number for the Micro SD Card Connector used on the FEZ Cerbuino Bee. I was going to use the Eagle drawing to implement this connector on a new board.
It is sourced from china. You will probably not be able to find it locally. Sadly, there is no “part number” in china! If you need hundreds/thousands, we can sell these direct to you.
Hi Andy,
There are a number of small Micro SD card sockets and Molex are a good source as Farnell etc stock these and you can get in small quantities.
I use the following with a ChipworkX design and now using it in a new G120 design.
http://sg.element14.com/molex/49225-0821/connector-micro-sd-push-push-8/dp/1366700?Ntt=1366700
You’ll need to create a new library part but that should not be an issue.
Thanks for the information. Will look into it.
