MH-Z16 CO2 sensor does not responding
I try to use MH-Z16 CO2 (datasheet is here). It uses the UART protocol. I connect it to 5 socket (SUY) to my Mountaineer Ethernet board.
Get power (5 volts) from socket - pin 2. And connect TX to 4 pin and RX to 5 pin. Then I tried to send command to sensor and get response from it. Nothing happens. Write method works silently, but Read method freezes the program. If I use ReadTimeout property method Read returns zero:(. May be I’m doing something wrond again?
using System.IO.Ports;
namespace SensorsDebug
            var s = new SerialPort(Mountaineer.Netmf.Hardware.Socket5.SerialPortName, 9600, Parity.None, 8, StopBits.One);
            s.Open();
            var buf = new byte[] {0xff, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
            s.Write(buf, 0, 9);
            s.Flush();
            Thread.Sleep(100);
            var cnt = s.Read(buf, 0, 9);
my first thought is you should always try reversing TX and RX pins. Please check the comments on this product for a definition of UART Dyslexia. [url]https://www.sparkfun.com/products/449[/url]. It’s my biggest failure, and I now put jumpers on circuit boards in case I mess it up :slight_smile:
@ Brett - :clap: You are right! I reordered RX and TX pins and… it works now!!! Hooray!
Thanks!
gets the best of us - as well as me ;D .
