EMX Board
.NET Micro Framework 4.1
GHI NETMF 4.1.3
If I deploy my application with VS2010 the app runs without problems on the board, but if I use the mfdeploy tool to generate a deployment file and redeploy it on the device following errors occurs:
[italic]Resolving.
Assembly: Microsoft.SPOT.IO (4.1.2821.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.IO (4.1.3.0) needs assembly ‘GHIElectronics.NETMF.System’ (4.1.3.0)
Assembly: ALBA_Handheld (0.6.0.0) needs assembly ‘Microsoft.SPOT.Hardware.SerialPort’ (4.1.2821.0)
Assembly: ALBA_Handheld (0.6.0.0) needs assembly ‘Microsoft.SPOT.Graphics’ (4.1.2821.0)
Assembly: ALBA_Handheld (0.6.0.0) needs assembly ‘GHIElectronics.NETMF.IO ’ (4.1.3.0)
Assembly: ALBA_Handheld (0.6.0.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Assembly: ALBA_Handheld (0.6.0.0) needs assembly ‘GHIElectronics.NETMF.USBClient’ (4.1.3.0)
Assembly: ALBA_Handheld (0.6.0.0) needs assembly ‘Microsoft.SPOT.IO ’ (4.1.2821.0)
Assembly: ALBA_Handheld (0.6.0.0) needs assembly ‘System.IO ’ (4.1.2821.0)
Assembly: ALBA_Handheld (0.6.0.0) needs assembly ‘GHIElectronics.NETMF.Hardware’ (4.1.3.0)
Assembly: ALBA_Handheld (0.6.0.0) needs assembly ‘System.Xml’ (4.1.2821.0)
Assembly: System.IO (4.1.2821.0) needs assembly ‘Microsoft.SPOT.IO ’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.Hardware (4.1.3.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.1.2821.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Assembly: GHIElectronics.NETMF.System (4.1.3.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.1.2821.0)
Error: a3000000
Waiting for debug commands…[/italic]
Can anyone please help me with this issue?
User_5
January 25, 2011, 10:36am
2
This might because of incompatible TinyBooter.
Start fresh. See FEZ Cobra firmware update guide to re-download the firmware.
Make sure to start by erasing using the E command in bootloader.
When done try a deploy a ConsoleApplication first.
Then try your application. If you have problems, please give us the entire debug output.
We do not have the necessary up and down button for TinyBooter update on our own designed device.
Here are some addidional infos:
[italic]DeviceInfo:
HAL build info: 4.1.2821.0, Microsoft Copyright (C) Microsoft Corporation. All rig
OEM Product codes (vendor, model, SKU): 255, 0, 65535
Serial Numbers (module, system):
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Solution Build Info: 4.1.3.0, GHI Electronics, LLC
AppDomains:
default, id=1
Assemblies:
mscorlib,4.1.2821.0
Microsoft.SPOT.Native,4.1.2821.0
Microsoft.SPOT.IO ,4.1.2821.0
GHIElectronics.NETMF.Hardware.EMX,4.1.3.0
GHIElectronics.NETMF.IO ,4.1.3.0
Microsoft.SPOT.Hardware.Usb,4.1.2821.0
ALBA_Handheld,0.6.0.0
System.IO ,4.1.2821.0
GHIElectronics.NETMF.Hardware,4.1.3.0
Microsoft.SPOT.Hardware.SerialPort,4.1.2821.0
GHIElectronics.NETMF.System,4.1.3.0
[/italic]
[quote]We do not have the necessary up and down button for TinyBooter update on our own designed device.
[/quote]
If you switch to serial debugging and send special character to force the GHI loader by sending special character on power up. From there use E command to erase all and update everything.
…or you can have your hardware guys wire the buttons right to the module
…or use in-field update feature to load tinybooter from software.
You must have a matching version of tinybooter and firmware.
Thank you for your reply. I will use now “in field update” with sd.card as described here: http://www.ghielectronics.com/downloads/NETMF_Beta/Library%20Documentation/html/53c9fe92-8150-bd36-e2de-bf4fc6f13f8f.htm
I’m not sure which files I have to copy to the sd-card? I tried with following files:
CLR.hex
CLR2.hex
Config.hex
app.hex
managedBootloader.hex
TinyBooter.GHI
How can I get the managedBootloader file?
Why are you looking in beta files? Please use official release, for docs and for SDK
http://www.ghielectronics.com/downloads/NETMF/Library%20Documentation/html/53c9fe92-8150-bd36-e2de-bf4fc6f13f8f.htm
That page has a lot of details
