MessageBox Issue
Hi! I have added a button with the following code:
#region Close
static void InitClose()
	// Get the Button
	Button Close = (Button)window.GetChildByName("close");
	// Listen for tap events
	Close.TapEvent += new OnTap(Close_TapEvent);
// Handle tap events
static void Close_TapEvent(object sender)
	ModalResult result = Glide.MessageBoxManager.Show("Do you want to save settings?", "Closing...", ModalButtons.YesNo); //Yes == 6; No == 7
	Debug.Print("Result: " + result.ToString());
 #endregion
The problem is that if I press “Yes” the keyboard dialog is opened and saved in this other control:
#region colatime
static void Initcolatime()
	// Get the colatime
	TextBox colatime = (TextBox)window.GetChildByName("colatime");
	// Add a tap event handler to open the keyboard.
	colatime.TapEvent += new OnTap(Glide.OpenKeyboard);
	// Add a value changed handler.
	colatime.ValueChangedEvent += new OnValueChanged(colatime_ValueChangedEvent);
// Print out the new value.
static void colatime_ValueChangedEvent(object sender)
	Debug.Print(colatime.Text);
 #endregion
Any idea about why is this happening??
Thanks!!
This is probably related to this issue
http://www.tinyclr.com/forum/22/5022/
