I’m doing a SAM9RL64 port (the same uP used on the Hydra), and I had initially planned on using 32-bit SDRAM along with 8-bit parallel flash memory, but it’s turning into a routing headache. I see the FEZ Hydra uses 16-bit RAM, and a serial SPI flash memory chip. Can anyone (probably Gus?) take a guess at what sort of performance difference I’d see between these two solutions? I’m trying to figure out what’s going to bottleneck the system the most.
I am not allowed to answer such question. These fall under paid support and consulting services. But I will answer hoping you will send GHI a case of beer one day, you won’t see much more performance going from 16bit to 32bit. I would say 10% to 20%. So not worth the extra needed work.
Thanks for the info. What about the serial flash? I’ve never used that before for anything but low-speed data acquisition. I know you guys use parallel flash on the EMX and some of the other products – I don’t know how the CLR works. Are programs immediately loaded from Flash into RAM at the beginning? Does anything execute from Flash memory? It sounds slooooow.
I’ll gladly send GHI a case of beer when I’m done with this project! It’s going to be open-source, so look for the design files soon!
