I was able to completely eliminate my init code, since it was solely concerned with filling the vector of objects.
I also opted to do my own simplified implementation of the max function from since my needs were pretty simple, which saved another 0.2kB.
Thanks also for the debugging suggestion. Indeed, while I’m enjoying the challenge of a new language and platform, and for the most part find the limitations an opportunity to learn new techniques, there are times when working with mbuino and RETRO, or even Arduino, for that matter, reminds me of just how good we have it with Visual Studio and the rich debugging that’s available regardless of whether we’re doing desktop, web, or NETMF development.
I suppose I could get myself a JTAG debugger and set up a full dev environment for mbed, but I really like the simplicity of the browser-based IDE. Can’t have it all, I suppose.
I think this has mainly been answered already but just in case…
The flash number can be trusted. As you’ve already seen from other posts the standard libraries are large, avoiding them is the main method to keep things small.
The RAM number is correct but only up to a point.
It only counts statically allocated memory, it doesn’t allow for anything created on the stack or the heap. So an array of objects that is global or static will be correctly counted, an array of pointers to objects won’t include the memory to store the objects, nothing created using new or malloc() will be taken into account. Similarly if you have a large number of local variables your stack could get very large but that won’t show up in the RAM usage number.
Just to add to the fun on other mbeds (e.g. the LPC1768) it’s possible to have 150% RAM usage and still work fine by forcing the use of other RAM blocks that the compiler will normally avoid.
just skimmed through this thread again… my comment
[quote]For mbuino, the current heap size is 3072 bytes.[/quote] caught my eye. Many apologizes if it lead anybody down the wrong path… rather than type the wrong thing again, the authoritative comment is the source code
fragment from startup_LPC11xx.s for mbuino:
Stack_Size EQU 0x00000400
AREA STACK, NOINIT, READWRITE, ALIGN=3
EXPORT __initial_sp
Stack_Mem SPACE Stack_Size
__initial_sp EQU 0x10001800 ; Top of RAM from LPC11U
Heap_Size EQU 0x00000000
AREA HEAP, NOINIT, READWRITE, ALIGN=3
EXPORT __heap_base
EXPORT __heap_limit
__heap_base
Heap_Mem SPACE Heap_Size
__heap_limit
the 3K limit (that I wrongly stated as heap) was from some experimental source code that I was using (as a a correct suggestion by Gus ) to debug a strange run-time error.
