Hey guys, just a quick question, can serial in take 5V?
Yes, as long as it’s not much more than that, and isn’t a shared analog pin.
Thanks… Well in that case I’m having a rather weird problem - I try to read data from a serial pin and I keep getting just 0 - Funny thing is, it worked a second ago and I didn’t change anything… And the serial signal is still definitelly there…
Its connected to a radio receiver… Really can’t work out what could be wrong.
Also, any clue why
SerialPort radio = new SerialPort("COM2", 600);
radio.Open();
byte[] check = new byte[1];
char[] ch = new char[1];
radio.Read(check, 0, 1);
ch = Encoding.UTF8.GetChars(check);
Throws an exception in mscore? Thats if the value actually ever gets read, which it currently isn’t. I’m really not having a good day
You aren’t using a full swing RS232 on one side, and the TTL inputs on the Fez side are you?
Nope got it down to 3v3 now - So I have a 3v3 signal on the input line, not got an oscilloscope handy but when i turn on the transmitter voltage on that pin raises to ~3.27V, and when I turn it off it drops to ~1.3.
And all that time the panda is refusing to read any data - I would be happy with anything, even complete junk. Instead its just not reading anything - With the above code, it never gets to the UTF8 bit.
I’m a little bit stressed out - this project is entering a competition tomorrow, and is going to get seen by hundreds of people. And it has decided to not work. Fml
Connect RX to TX then you can test that you can receive what you send.
Good idea, thanks I’ll try that now.
Loopback does indeed work. I guess it must be something with my radio module output - that’s strange, it worked just a minute ago :/.
What kind of problems would cause the controller not to get any reading at all from a serial pin? If it was strange/random data, that I could understand, but why might it get no reading at all?
