The standard OnInterrupt handler is passed the parameters (uint port, uint state, DateTime time). It looks like the port is “defined” for a particular board eg Di13 = 42, Di1 = 18, Di-0= 20.
If so is it possible to have a single general OnInterrupt handler with a switch on port number?
Will Domino Di13 always be port 42 on a Domino?
The reason I’m asking is I’m making a pseudo Finite State Machine where the real world inputs are responsible for initiating state changes. It would be quite neat to wrap it all up in a single general handler.
It may not be bad practice, but is it good practice?
Now I’m light on C# experience. I have looked on MS .NETFM and couldn’t drop on an answer but…
I understand how to make a port an interrupt pin. I tried a couple of hacks to add a second pin to an existing interrupt handler. But I just generated errors along the lines of there’s already a handler.
Yes it is a good practice, keeping in mind that the one handler will take care of more than one pin so there is a slight overhead to figure out which pin is the interrupt source. In most cases, this is okay.
Here is a sample, I have not looked at the glitch (debounce) handling for this. So the same event may fire multiple times. This is on the Cobra, you may want to use some other routine in the absence of a display (blink RED, blink GREEN).
using CobraLCD;
static Bitmap LCD;
static Font MyFont;
MyFont = Resources.GetFont(Resources.FontResources.small);
LCD = new Bitmap(SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight);
LCD.Clear();
LCD.DrawText("Interrupt Mon", MyFont, Colors.Red, 10, 10);
LCD.Flush();
InterruptPort Port1 = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.IO19, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeBoth);
InterruptPort Port2 = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.IO18, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeBoth);
//Event handler is the same for both ports
Port1.OnInterrupt += new NativeEventHandler(Portx_OnInterrupt);
Port2.OnInterrupt += new NativeEventHandler(Portx_OnInterrupt);
static void Portx_OnInterrupt(uint port, uint state, DateTime time)
//figure out the port
switch (port)
case 19 :
Display(port);
break;
case 18:
Display(port);
break;
default:
Display(0);
break;
static void Display(uint port)
LCD.Clear();
LCD.DrawText("Interrupt source is Port : " + port, MyFont, Colors.Red, 10, 10);
LCD.Flush();
