Hello,
I am prototyping possible interactions on a smartwatch using the Display N18 module as the watch screen. I am using the Raptor as my mainboard.
For convenience to wear the watch and also be able to move around a little bit, I need the gadgeteer cable connecting the raptor and display N18 to be sufficiently long. I am aware from some of the previous threads that it is possible to use either an extender module or make a longer gadgeteer cables depending on the socket in use.
Does anyone have any suggestion on which approach would work better in this case for the socket type S?
