Long running timers / timeouts
What is a good pattern to use for a set of long running timers? For example, when an action occurs (interrupt triggers a relay to close for example, and a LED stays lit indicating that happened) I then need a 1 minute timeout before doing one action and a 10 minute timeout before doing another action. It’s likely I’ll have multiple events, each possibly requiring multiple timers well beyond seconds. Anyone with thoughts on clean ways of handling that ?
@ Brett - See if the code below helps. Should convert quickly to MF.
using System.Collections.Generic;
namespace CommonLibrary
    // returning true will result in the task being reequeued with same delay
    public delegate bool TimeTaskDelegate(int id, Object state);
    public class TimerTaskManager
        private class TaskBlock
            public int ID { get; set; }
            public TimeTaskDelegate TaskDelegate {get;set;}
            public int DelayMS { get; set; }
            public DateTime expireTime { get; set; }
            public Object State { get; set; }
            public TaskBlock Next { get; set; }
        private TaskBlock freeTaskBlocks = null;
        private TaskBlock pendingTaskQueue = null;
        private Queue<TaskBlock> executionReadyQueue = new Queue<TaskBlock>();
        private AutoResetEvent readyToExecuteEvent = new AutoResetEvent(false);
        private List<Thread> executeThreadList = new List<Thread>();
        private AutoResetEvent scheduleChangedEvent = new AutoResetEvent(false);
        private int numberOfTasks = -1;
        public TimerTaskManager(int numberOfThreads, int initialNumberOfTaskBlock = 5)
            this.numberOfTasks = numberOfThreads;
            for (int i=0;i<initialNumberOfTaskBlock;i++)
                TaskBlock newBlock = new TaskBlock();
                newBlock.Next = freeTaskBlocks;
                freeTaskBlocks = newBlock;
        public void Start()
            for (int i = 0; i < numberOfTasks; i++)
                Thread thread = new Thread(_ExecuteRun);
                thread.Start();
                executeThreadList.Add(thread);
            (new Thread(_ScheduleRun)).Start();
        private void PlaceInQueue(TaskBlock taskBlock)
            lock (this)
                taskBlock.Next = null;
                // place into queue
                bool atHeadOfQueue = false;
                if (pendingTaskQueue == null)
                    pendingTaskQueue = taskBlock;
                    atHeadOfQueue = true;
                    TaskBlock lastTaskBlock = null;
                    TaskBlock currentTaskBlock = pendingTaskQueue;
                    while (currentTaskBlock != null)
                        if (taskBlock.expireTime <= currentTaskBlock.expireTime)
                            if (lastTaskBlock == null)
                                // at head of queue
                                taskBlock.Next = currentTaskBlock;
                                // insert
                                lastTaskBlock.Next = taskBlock;
                            break;
                        lastTaskBlock = currentTaskBlock;
                        currentTaskBlock = currentTaskBlock.Next;
                    if (currentTaskBlock == null)
                        //need to place at tail of queue
                if (atHeadOfQueue)
                    scheduleChangedEvent.Set();
        public void Schedule(int id, int milliseconds, TimeTaskDelegate task, Object state = null)
            // calculate expiration time
            DateTime expires = DateTime.Now.AddMilliseconds(milliseconds);
            lock (this)
                // get a free task block
                TaskBlock newTaskBlock;
                if (freeTaskBlocks == null)
                    newTaskBlock = new TaskBlock();
                    newTaskBlock = freeTaskBlocks;
                    freeTaskBlocks = newTaskBlock.Next;
                // format block
                newTaskBlock.ID = id;
                newTaskBlock.DelayMS = milliseconds;
                newTaskBlock.expireTime = expires;
                newTaskBlock.TaskDelegate = task;
                newTaskBlock.State = state;
                PlaceInQueue(newTaskBlock);
        private void _ScheduleRun()
            Thread.CurrentThread.Name = "TimerTaskManagerSchedulerThread";
                Monitor.Enter(this);
                    //Debug.Print("Waiting on empty queue");
                    Monitor.Exit(this);
                    scheduleChangedEvent.WaitOne();
                    continue;
                DateTime now = DateTime.Now;
                TaskBlock expiredTaskBlock = null;
                if (pendingTaskQueue.expireTime <= now)
                    //Debug.Print("Head of queue expired");
                    // it has expired
                    expiredTaskBlock = pendingTaskQueue;
                    pendingTaskQueue = expiredTaskBlock.Next;
                if (expiredTaskBlock != null)
                    // schedule for execution
                    executionReadyQueue.Enqueue(expiredTaskBlock);
                    readyToExecuteEvent.Set();
                int sleepTimeMS = -1;
                if (pendingTaskQueue != null)
                    TimeSpan elapsedTimeToNextExpire = pendingTaskQueue.expireTime - now;
                    sleepTimeMS = (int)elapsedTimeToNextExpire.TotalMilliseconds;
                Monitor.Exit(this);
                if (sleepTimeMS == 0)
                    continue;
                if (sleepTimeMS > 0)
                    //Debug.Print("Sleeping for " + sleepTimeMS.ToString() + "ms");
                    scheduleChangedEvent.WaitOne(sleepTimeMS, false);
        private void _ExecuteRun()
            Thread.CurrentThread.Name = "TimerTaskManagerExecutionThread";
                // wait for event
                readyToExecuteEvent.WaitOne();
                lock (this)
                    if (executionReadyQueue.Count == 0)
                        continue; // nothing to do
                    expiredTaskBlock = executionReadyQueue.Dequeue();
                    // see if we need awake another thread
                    if (executionReadyQueue.Count > 0)
                // we now have a taskblock to execute
                if (expiredTaskBlock.TaskDelegate(expiredTaskBlock.ID, expiredTaskBlock.State))
                    expiredTaskBlock.expireTime = DateTime.Now.AddMilliseconds(expiredTaskBlock.DelayMS);
                    PlaceInQueue(expiredTaskBlock);
                    // return to free queue
                    lock (this)
                        expiredTaskBlock.Next = freeTaskBlocks;
                        freeTaskBlocks = expiredTaskBlock;
