I need DL40 module 1,5 metre away from microcontroler. I use 2 breakout modules and connect them with utp cable. The application works, if i connect this 2 modules with 10cm cables. But if I use 1,5 metre utp cable the deployment failed.
Output window:
[quote]
Found debugger!
Create TS.
Loading start at a0e856b0, end a0e9ce0c
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2.0.0)
Assembly: System.Security (4.2.0.0) Loading Deployment Assemblies.
Resolving.
GC: 1msec 277428 bytes used, 7062240 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 7062240 bytes
Type 17 (ASSEMBLY ): 11112 bytes
Type 1E (BINARY_BLOB_HEAD ): 266220 bytes
GC: performing heap compaction…
Ready.
Cannot find any entrypoint!
Done.
Waiting for debug commands…
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Security.dll’, Symbols loaded.
The program ‘[14] Micro Framework application: Managed’ has exited with code 0 (0x0).[/quote]
Does somebody knows what this mean?
Did somebody try something like this?
