when i use windows 8 i get the ghi bootloader interface device. mf deploy cant connect.
using fez config 011 or 13 the device changes to emx with no driver installed ?
the same happens with windows 7 32 bits mfdeploy let driver bootloader the same, starting fezconfig 013 gives unknown emx device in windows devicemanager
i can now do usb debugging through the usb dp client module with the new ghi software package 4.2.
but it seems the usb dp client module has lost its capapility to debug through a serial port with the new software. i still can debug serial through a serial usb client module or pure serial module.
IF you mean combined CDC functionality and debugging, GHI deprecated support for CDC + Debug in 4.2 because of the support issues. That’s not related to anything other than it’s a support issue generator so to remove that complexity you just add a serial port on COM1 and debug over that.
