Load Module (LOADA-GM-364) Maximum Switch Rate / Optical Encoder Simulation
I am looking to simulate an optical encoder / odometer sensor for a test rig and planned on using the GHI Load module (LOADA-GM-364) to generate the pulse train (12-24 V).
Is there any documentation on the maximum switch rate the module can accomplish?
For my application, I am looking for 120 Hz, but wondered what the limit was.
Is there a better technique or module to use for this purpose?
That modules uses BCP55 transistors.
According to this:
http://www.newark.com/nxp/bcp55-115/biplr-transistor-med-pwr-npn-60v/dp/70R2214
Typical frequency is 180MHz.
You should be fine!
