LittleStep Stepping Speed
SolderMonkey,
I have a second question for you. I need to calculate the step rate based on the desired completion time of a move. I have the math for this and I know the value for my required steps per second. The “littleStep.StepRate” says that the integer value should be in steps per second. The problem is anything higher than 1 causes the motion to behave irradically. I would assume this is because the rate is too high. I don’t think this value is really steps per second, as I am completing a 4200+ step move in 3.2 s.
I need to be able to adjust the rate but since the number is an integer I can’t put in decimals. Perhaps I am using this incorrectly. Here’s how I am using this.
littleStep.StepRate = 1;
@ Jermtown -
You probably going to get a better response time if you try contact him through his site. Unless somebody (DukeNukem) has his modules.
good point, I’ve emailed him there also. I’m leaving this open to post his answer.
I know nothing about the module but I ran across this…
Maybe some help? Not even sure if the link is the same module.
Parallax info:
http://www.google.com/search?sourceid=navclient&aq=hts&oq=&ie=UTF-8&rlz=1T4GGHP_enUS472US473&q=littleStep.StepRate
This should be the full link to opening/download the PDF
http://www.google.com/url?sa=t&rct=j&q=littlestep.steprate&source=web&cd=5&ved=0CE0QFjAE&url=http%3A%2F%2Fforums.parallax.com%2Fattachment.php%3Fattachmentid%3D65107%26d%3D1258155661&ei=OJPdUOyPNcy8qAGp_YFo&usg=AFQjCNFN6I1RPwuYxvnrgBQGSY8fk1A8Xg&bvm=bv.1355534169,d.aWM
