Hmm, using a spindle, technically with a â3 axisâ setup, you could do probably the equivalent of a 4 axis CNC due to the tilt on the cutting headâŠ
That would be a good project to work on too.
Although a Rostock would be overkill for PCB printing, unless you want to do 2.5 or 3D PCBs
The head on the Rostock doesnât tilt, it stays parallel with the bed.
If you put tilting mounts on the 3 arms, Iâm not sure youâd have any control over the tilt without some sort of actuator setup. It would effectively be 3 more axes, I believe. I could be wrong here.
@ godefroi, True; however is is possible to make them rigid enough to mill. 3 Years ago, I did not see any delta robotâs rigid enough to mill with. They were supposed to be for light duty work only. Now that is totally changed. Now, we have to build parallel robots for milling work. We must definitely pursue this goal.
Yeah, I realize most delta implementations do keep the head parallel to the build surface⊠I was thinking that if you made two of the axes pull higher than the third, it would tilt, without an actuator⊠would have to do some experimenting to see exactly how precise you could keep it.
Thatâs exactly what I was thinking, but without having âproperâ motor control on the extra 3 axes on the head.
Yep, I didnât think about shortening/lengthening the arms themselves, but that would probably be a better control design than just having fixed length arms raised and lowered at different heights⊠then again, itâs all math, so it may not make much differenceâŠ
Changing the arm length changes the effector position not tilt. As you raise one or more arms this effectively changes their lengths moving the level effector which, remains parallel to the given plane within 3D space. The only way to tilt the effector is as shown in the video. Manually twist the jointâs attach points. Or if you want motion without such complexity then place rotation on the effector.
The delta is cool because you can readily draw all over a given 3D space a plane at a time which is the FDM method done with filament hotend supplied printers.
If you move all three, I agree. I am saying move two of the arms and not the third, so that the tool platform doesnât remain parallel to the build surface. If you have a flat surface, and move two of the three arms up, the platform has no choice but to tilt (assuming it doesnât bind).
I am very familiar with hot end printing techniques. I have a MakerBot Replicator and another RepRap variant, as well as a 3D CNC router, another router and laser cutter build in progress.
