Lemur SD Card
I’m trying to use the SD card on my Lemur board without success.
I’m using VS2015 and GHI SDK 4.3 along with the code example here.
https://www.ghielectronics.com/docs/51/accessing-folders-and-files
The code builds ok but when I deploy I get the error message
Assembly: GTM.GHIElectronics.SDCard (4.3.7.10) needs assembly ‘Gadgeteer’ (2.43.1.0)
I can’t see any reference to this anywhere.
Disaster!!
It now won’t deploy any code to the board.
When I press LDR0 and reset it appears on Com3 but USBizi won’t connect to it. If I just press reset and go to Fez Config, under USB G30_G30 appears briefly then dissapears, and I can’t connect to it.
Please help.
Well once again the problem seems to be the person sitting in front of the computer. Trying to download a program to the board which was too large.
Question:
How do you determine the file size before deployment?
