Hi all,
I just see that the LED Matrix is discontinued. I wonder if there are plans to replace it with a new component, for example a multicolor LED Matrix or an enhanced LED Matrix ?
Regards,
Ronald
Hi all,
Regards,
Ronald
Not for now but I wouldn’t be surprised if someone in the community made one.
Have you considered using addressable LEDs instead?
Welcome to the community
16x32 RGB LED matrix ($24.95): Medium 16x32 RGB LED matrix panel - 6mm Pitch : ID 420 : $24.95 : Adafruit Industries, Unique & fun DIY electronics and kits
Or, check eBay. Single-color 8x8 matrices go for <$1 when you buy 10 at a time there.
Maybe a controller for the Adafruit panel would be a good project for the mBuino.
Thanks.
I had the chance to order some LED Matrix during the latest promotion, so it’s OK for the moment.
I see that the module has been removed from the kit, but the code is simple and works with the DL40 DaisyLink module, so it works well.
Regards
